Want to integrate ipod...
Old 11-10-2004 | 07:06 AM
Silver996TT's Avatar
Silver996TT is infamous around these parts
Question Want to integrate ipod...
I have a 01 Porsche 911 Turbo with Nav.
I want to intergrate iPod Mini to my car.
Anybody done this before?
I found some sources w/o Nav., wondering if it is the same?
Thanks,
Dale
Old 11-10-2004 | 07:33 AM
NYSEGuy's Avatar
NYSEGuy is infamous around these parts
Not sure how simple or complicated you want to get, but I've been using the itrip with success.
Old 11-10-2004 | 08:02 AM
I have iTrip, but the quality of sound is very bad.
I know some people using Becker Aux to connect to the stereo head unit, but I don't know if its the same way for doing it on a Nav.
Old 11-10-2004 | 08:43 AM
raygr's Avatar
raygr is infamous around these parts
I've done it on my 02 TT with this:
iceLink
It's wired into the CD-changer inputs on the back of the head unit, so you lose the CD-changer. But, it sounds much better than iTrip.
Old 11-10-2004 | 09:23 AM
Do you know if its compatible with 01 Nav?
Old 11-12-2004 | 03:27 PM
raygr's Avatar
Sorry - not sure. I would call them up and ask. I'm guessing yes, if you can attach the CD changer.
Old 11-12-2004 | 03:45 PM
Moogle's Avatar
Moogle is infamous around these parts
iTrip is OK, but once you listen to music with a lot of hi-end or low-end, it can't handle it,a nd it becomes interference
Old 11-12-2004 | 11:12 PM
Thank you Ray!
Old 11-13-2004 | 06:49 AM
Pistol's Avatar
Pistol is infamous around these partsPistol is infamous around these partsPistol is infamous around these partsPistol is infamous around these parts
if you are worried with sound quality u should def make all ur mp3s into wav format.
Old 11-13-2004 | 06:56 AM
KJM3's Avatar
KJM3 is infamous around these parts
That's far from an ideal solution. wav files are much too big in size. If you're going to do that, you might as well just burn it onto a CD and listen to it like a regular CD.
The best solution would be to use a higher bitrate .wma file or an .aac file. Both sound better than MP3 at the equivalent bitrate with similiar file sizes.
If you encode a .wma or .aac file at 256 kbps, it will be of CD quality and still be very reasonably sized.
- KJ
navtool.com
Lexus Vendor Classifieds
10-01-2015 11:14 AM
navtool.com
NY Tri State
10-01-2015 11:13 AM
navtool.com
10-01-2015 11:13 AM
navtool.com
10-01-2015 11:10 AM
navtool.com
BMW Vendor Classifieds
10-01-2015 11:09 AM
Quick Reply: Want to integrate ipod...
