quick maf cleaning tip
first off, thanks to everyone here for all the various posts on cleaning the maf. you guys saved me $300!
I just wanted to say if the electrical contact spray cleaner does not work by itself, try using a qtip to clean all the various metal contact points. that is what did the trick for me. the spray alone didn't do it. I guess I had too much K&N oil on my techart (K&N) filter.
also, make sure when the maf is installed back, you got the arrow pointing in the right direction.
p.s. anyone want to purchase a techart filter.........
lol at the for sale plug!
Just a note to those that might use the q-tip method: just be VERY VERY delicate with the q-tip as these parts are very fragile and can be ruined very easily using this method. Also, make sure you dont leave any stray fibers on the filaments.
cleaning the MAF is definitely one of those things that can save you a bunch of money and cure a poorly running car.
You really shouldn't touch the wire at the end of the MAF...it's sensitive and can be easily ruined by rubbing it.....I've never heard of using a Q tip on it before...just the spray with the CRC and letting it air dry.
i just used the elec cleaner and it worked like a charm . hey chuck nice to see ya. looked for you at euro sunday last weekend .got a new front lip commin from vivid and am tryiintotypewith my left hand (the strke hand) ok so the left hand stillis notpurfect yet..this is thr right hand typin now way better
Any particular detergent? We have hard water - does that matter?
Make sure you use that Jet Dry stuff to eliminate water spots--that makes all the difference
Make sure it is a Bosch dishwasher for maximum effectiveness and compatibility. you will be able to feel the performance difference if you use anything else.
I'mAllIn
09-11-2015 06:38 AM
