rattle at idle LWFW need some opinions
Old 09-15-2009, 08:53 AM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
Originally Posted by frankster
Wow! You guys have me all psyched up to get PERFECTLY BALANCED lwfw as well as the appropriare tuning to go with it . . .
Until then, I will have to give William a hard time. . .
Dude, my stock flywheel works GREAT!
Jeez, I crack myself up!
your flywheel might be great but lets go to LMP and go for a run n see whos car works better frankster =)
  #32
Old 09-29-2009, 05:52 AM
Dock (Atlanta)'s Avatar
Dock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really nice
Originally Posted by ari
Has anyone noticed any noises beyond idle?
My car makes a grinding noise until about 2500 RPM in gear under load.
Yes. I have the "marbles in a coffee can " sound at idle with the clutch released, and that same sound can be heard up to about 2000-2500 RPM under easier accelerations.
  #33
Old 09-29-2009, 09:50 AM
Mad Ness's Avatar
Mad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant future
sorry semi off topic...
New to P's and confused. Have had LWFWs before and they only make that marbles in tin can noise when the clutch pedal is pressed to the floor, for all gears. But if I understand correctly, the 996tt LWFWs do this while clutch pedal is in up position, gear in neutral?
  #34
Old 09-29-2009, 09:54 AM
bmoores's Avatar
bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !
correct
  #35
Old 09-29-2009, 10:20 AM
Mad Ness's Avatar
Originally Posted by bmoores
correct
hope it's not as loud as what Im used to with past cars, the neighbors are going to love it when the car's warming up every morning... my left calf is finally going to be proportionate to the right.
why is that? not why it makes the noise, but why the difference to what i've experienced with japanese cars. (just let me know if i should start a new topic)thanks.
  #36
Old 09-29-2009, 10:33 AM
$manager's Avatar
$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !
No idea why...but I can tell you exactly what it sounds like. Jump into any diesel sportfishing boat and fire the CATS/MANS/MTUS up. With the boat idling in neutral......there you have it. And I mean exactly.
  #37
Old 09-29-2009, 12:37 PM
Prche951's Avatar
yup, diesel is a good way to describe it. If you have ever heard a Ducatti, that clacking sound it makes is exactly like the lwfw. once you are rolling you don't hear it much. My exhaust is fairly loud so I don't hear it anyway
  #38
Old 09-29-2009, 12:43 PM
ttboost's Avatar
I ride my buddy's 916 once in a while and I always think I ran it out of oil!!!
  #39
Old 09-29-2009, 12:48 PM
Prche951's Avatar
well if the engine shuts down and locks the rear wheel on you, then you are correct
  #40
Old 09-29-2009, 05:03 PM
ReeknHavic's Avatar
ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !
That's a very good comparison. I'd like to know why some lwfw are annoyingly loud and some are very quiet. Does anyone know what component is to blame for all the ruckus? I guess I got lucky, mine is extremely quiet.
  #41
Old 09-29-2009, 05:24 PM
$manager's Avatar
...or it is still new..hopefully you are the lucky one though. When they first go in they do not rattle anything like they do after a couple thousand miles.
  #42
Old 09-29-2009, 05:26 PM
ttboost's Avatar
I believe the DMFW dampens the transmission gears and other driveline noise. It just provides some inertia. (I personally think that I lose more boost now between shifts with the LWFW vs the DMFW). Some LWFW's are heavier than others. Some are 8-9lbs, some are 12-13lbs and I think there is one a little heavier, all versus the stock 31lbs.
  #43
Old 09-30-2009, 04:23 PM
Prche951's Avatar
very interesting observations. I wonder if this indeed the case. Definitely gain power by going to lwfw due to less rotating mass, some claim 10-15 whp.
  #44
Old 09-30-2009, 04:47 PM
ReeknHavic's Avatar
I've got about 4000 miles on my ATS triple carbon.
  #45
Old 09-30-2009, 11:22 PM
that is a completely different type of clutch then most in this thread are running haven't heard of any issues with the triple plate clutches
Quick Reply: rattle at idle LWFW need some opinions
