Clicking Sound in Rear Axle?
Is anyone familiar with a clicking from the rear? It is very light and can only be heard with the window down and driving close to a curb or between buildings. If you are going straight or turning right it is more noticeable. Turn to left and it stops completely. I pulled the CV boot back and the joint looked like it could use more grease. I worked some CV lube into the area and made sure ample grease was around each ball bearing. No change...Is there a kit or are new axles the only answer?
Also, be sure not something in rotor hole or even something in tire like a nail or screw or something sticking out making contact with pavement as tire rotates.
As for the u-joint not right to just shove lube in there. Excess grease gest slung away from bearing and onto CV boot's inner surface. Can create a slight imbalance that can cause premature boot failure.
If you can't eliminate source of noise then half shaft removal and tear down probably called for.
After a good cleaning inspect for signs of wear or bearing distress. Any signs replace. If ok properly repack with proper grease and fit new boots and reassemble. Or just replace u-joint bearings with new ones and save the time to clean inspect and repack with grease. Be sure to fit new boots.
Sincerely,
Macster.
Fabspeed Motorsport
Audi
08-21-2015 11:30 AM
Yotam Refael
Cayenne
08-18-2015 03:03 PM
