Help my meth injection is not working!
Okay so I have been noticing that I have lower boost and the car just felt sluggish. I was going to add some more meth and notice that the tank was still full! So I punched it and noticed that the gauge that shows the flow level of the injection system wasn't lighting up. The only thing is that at the end of the gauge there is a "B" and that would flash when I punch it. I checked all the fuses and the power connection. Everything looks fine, however, cant get the pump to work.
Anyone know what is going on? Im getting frustrated. I will check with Tony tomorrow but Im praying that there is some stupid button or fuse hidden somewhere that got triggered.
Im pretty sure its your fail safe feature on your gauge, it has to do with your wl and wh settings, when your out of the fail safe zone "b" you will not boost, i had the same problem. Call Jeff at howertonengineering 707-685-6279, he will tell you how to set it up. Hope this helps.
Your boost is low because your failsafe is working exactly as designed (the main reason we use Aquamist). Dave or myself will call you shortly.
COBB Tuning
03-29-2016 09:26 PM
nlakind
11-06-2015 10:15 AM
sdg1871
09-12-2015 06:54 AM
COBB Tuning
09-09-2015 09:13 PM
