Do you really need big heads/valves for nearly 1000hp?
Nope, I just got my car dialed in at EVOMS today getting ready for the mile and we put the car back on the dyno in weather similar to that which topgun made his 805AWHP. Our cars make an interesting comparison since both are near identical builds except for the head configuration. Tom has a world class port job on stock turbo heads, stock valves and EVOMS sport intake/exhaust cams. I have a heavy port job with oversize Ferrea intake /exhaust valves and a custom ground exhaust cam with an OEM stock intake cam. Our final numbers were approximately 800/730 AWHP for me and 805/760AWHP for Tom. Clearly, if you are looking for the 950-975 crank HP range you dont need big fancy heads and valves. We had equal HP at the end of the run but Tom made more, sooner and held it longer giving him a substantial advantage. Same with TQ. I have much more headroom for future work since my power is still climbing whereas Tom is flatlining due to the small valves, but overall he has a better, cheaper package. Just for the record we were running the EXACT same file and all other hardware was identical..... Todd was kind enough to overlay Joes new numbers on our graph as well just to let Tom and I know we have real small peckers.... Joe, Tom and I will meet you at the stoplight of your choosing!!!
The issue is .......... you have to run a lot of boost to get there. This is where quickness and response comes into play.
In addition, the flow of the heads doesn't mean a thing without the proper displacement to match the flow of the heads. It all about proper design.
Everything makes sense except the title (800 whp is awesome....but it is not "near 1K" hp).
My car should be making about 725 or so after my next round of mods and I would love to make 800, don't get me wrong, but I would not exaggerate the #s.
well..... 800/.82= 975.6... seems close enough for comparison sakes, these are AWD cars. Now run along and sing me a song
OK....but you do know that all the other car enthusiasts, at least in my part of the world laugh at you when you are so insecure that you have to quote flywheel numbers.
On the other hand, when I say my little ol car only makes 680, and then I hang with a Supra that dynoes 800 plus, I tend to get more respect.
Dr why do u always doubt the dyno number? Has your car always come up short on the dyno than expected? The general drive loss on AWD is 18% and 15% on RWD. So just do the math.
KPG - I will soonn find out if 1000hp required the massive heads. Although Ill have stock ported and polished heads, cams, and gt35's. Todd is estimating anywhere from low to high 900's at the wheels.
Jag
Jag
run along little boy, write me a song or poem
Jag
Jag
Jag
Jag
Car dynoed 800...that is fantastic.
