Digital oil measure
Old 10-13-2009 | 07:22 AM
REELDEEP's Avatar
REELDEEP is infamous around these parts
Digital oil measure
Is there another way to read the oil level without using the digital display?
Any one ever heard of the oil measuring digital display reading wrong oil levels. My buddies 996 turbo reads full (oil)...1 min later he takes another measure it reads low (oil) with the low bar flashing. Takes it again it reads full, and then 1 min later low again. At one point it read 1/2 full or empty...depending how you look at it. This is all done on a flat surface with the car running and warmed up. There is no consistency; the readings of low and full are inconsistent.
Pete
Old 10-13-2009 | 08:15 AM
REELDEEP's Avatar
forgot to mention...he flashed the computer (FVD) about a month ago. The battery was disconnected for a week and we believe that is when the problem started.
Old 10-13-2009 | 11:44 AM
aroonkl's Avatar
aroonkl is a jewel in the rougharoonkl is a jewel in the rougharoonkl is a jewel in the rougharoonkl is a jewel in the rough
Might need to go to dealer/repair shop to find out. They should be close between each measurement. GL.
Old 10-14-2009 | 05:08 AM
REELDEEP's Avatar
Fixed
We found it.....there is a sensor that sits on top of the oil fill tube...a wire was loose.
ECS Tuning - VW
09-08-2015 01:34 PM
DLF
Cayenne Turbo
09-03-2015 01:36 PM
ECS Tuning - VW
09-02-2015 01:47 PM
ECS Tuning - VW
09-02-2015 01:19 PM
ECS Tuning - VW
09-02-2015 12:58 PM
Quick Reply: Digital oil measure
