Winter Tire Options??
Looking for winter tires and would rather not go with the normal 225/40/18 - 265/35/18 combination. This is due to the fact that 18x10 oem wheels are hard to find which is the recommended width for the 265. I would also rather go bigger than 265 on the rear wheels to keep it close to the 295 summer tires. I plan on driving during the winter but not in any deep snow so I don't think this will be an issue.
The new Blizzak LM-60 has a 225/40/18 - 275/35/18 combination available which would fit on the 18x11 rear tire better. This may be an option but would still rather go with a wider rear tire.
Found an interesting third option. Dunlop Winter Sport 3D in a 235/40/18 - 285/35/18 combination. Diameter difference is just under 2% which shouldn't be an issue with the all-wheel-drive. However, the tires are a little bigger than stock (about 0.5"-1.0"). What do you think? Is this a viable option for winter rubber?
Thanks.
Thanks.
Thanks.
Thanks.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
damon@tirerack.com
Or use this link:
For the TT, I like the look of the OEM turbo twists which are very difficult to find in 18x10. I have already found a set of 18x8 - 18x11 twists for a great price and am currently looking for the snows to throw on them.
I know some out there are putting 265s on the 11 inch rear but I am hesitant to do that as it is outside the recommended width range for the tire.
Damon,
I plan on driving the TT in the winter, however, when there is a lot of snow I obviously have other options (SUVs) to choose from.
I am looking for a tire that would be pliable in the winter, provide good performance and would be suitable for light snow. For the rear wheels, I would need to be 275+ to accomodate the 11 inch rear wheels. My only issue with the Blizzak LM-60s is that they are only H speed rated - not a deal breaker but would rather have V+ speed rated tires. What would you recommend?
cnebrask
Today 12:11 PM
horsepowerfarm
09-10-2015 06:09 PM
