What did it take for you to run 10seconds
#46
That is pretty darn close, but it can even be done with a little less than that +
drag radials really help. VERY, VERY FEW have done it on 19" PS2's and All WHEEL DRIVE like my car had. 18" or 17" Drag Radials + disconnect front wheel drive seems
to do the trick (obviously tightens up the 60').
MK
MK
#47
No kidding, for $1900 bux I'd be down at the truck shop and hitting MSC myself! The ABS plastic one I've seen maybe but that?!
#48
not just industrial tubing, but redesigned and built intake plenum, which flows much better than the factory unit. Definitely worth the money if you are making good power, not just a flash. Also install is a *****. Usually done along with clutch. Not worth the labor otherwise.
