Gauge Setup
Gauge Setup
I am going with a custom Defi Gauge Setup. I will either go with 2-5 gauges, not sure yet my exact setup. You have to install the Defi BF Gauge Control Unit II. Then you have the following choice of gauges:
- Boost
- Ehaust Temp.
- Fuel Pressure
- Oil Pressure
- Oil Temp.
- Water Temp.
In order of importance, how would you rank the top 5. Thank you.
- Boost
- Ehaust Temp.
- Fuel Pressure
- Oil Pressure
- Oil Temp.
- Water Temp.
1-3 need to all go together. All 3 are important enough and have even more conclusive results when seen together.
1. Analog Boost Pressure
2. Exhaust Gas Temperature
3. O2/Air-Fuel Ratio (I would move this up to #2 if you run a wideband O2 sensor, otherwise it will help, but not as much as your EGT gauges).
4. Fuel Pressure
5. Oil Temp
4. Fuel Pressure
5. Oil Temp
Ken =_=" that's rediculous pricing...
talk to Alex @ SP Engineering... I have Defi Gauges... 5 of them...
trust me they don't cost that much... I even had SP custom made me a carbon dash
I've got the Defi boost & exhaust gauges. Nice choice! Be sure to post pics after the install.
Call SP for the hookup!
COBB Tuning
01-05-2016 07:06 AM
speedsterr
10-26-2015 09:18 AM
