PCM on 2004 loses its memory settings
I am facing a strange issue with PCM on a 996 2004. The car loses all its setiings and memories when the ignition is switched off.
Has anyone come throught this before ?
TIA
TIA
Battery is good. It starts the car well. Cant be it, as PCM only needs a very small amount of power to keep "thinking"
I suspect an internal PCM error. There is usually a line that is always on, then another line that is switched. The component will always 'draw power' from the constant line, but uses the 'swtiched' line to tell it to go off (technically standby), etc. Perhaps something got corrupted, or an internal fault, and when it goes to standby it doesn't write the current values to memory? I can think of may scenarios that might explain this. I would unplug the PCM for a hour or two, then reconnect. Past that, I wouldn't have a clue.
A
PS Of course there has been no modifications to the electrical system, recently or in the past, right?
A
A
A
no mods or else done to the cars electrics
Try testing the alway hot wire for power.
Removing and replacing the wiring harness may fix a faulty connection as well.
Start with the simple stuff and work your up to the more complex.
So disconnecting it and seeing if it 'resets' didn't work??
04-28-2022 12:38 AM
2lflat4
11-18-2019 05:05 PM
10-06-2015 03:43 PM
pshep138
09-01-2015 09:45 AM
