Preliminary Dyno Numbers K24/20g's
Old 10-22-2009 | 06:02 PM
bmoores's Avatar
bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !
Well we had a little trouble on the dyno this evening with wheelspin. 4th gear pulls. We tightened the car down a few times but just couldn't get it to put all the power down without wheelspin. 625hp/575tq going to redyno tomorrow or Saturday with DR's on to see if they'll stick any better. Temp was 76 degrees with 40% humidity for anyone that cares on a Dyno Jet Dyno. Fans on IC's and on front radiator. Boost was @ 1.42 bar. Happy with the numbers considering everything but i think there is a little more in it.
Old 10-22-2009 | 06:07 PM
Divexxtreme's Avatar
Very nice, Ben. But yes, she has more than that in her.
Old 10-22-2009 | 06:09 PM
bmoores's Avatar
I'm not sandbagging I promise Scott. I'll report back when we have drama free numbers.
Old 10-22-2009 | 06:36 PM
MBailey's Avatar
Ben,
I bet she has at least 25 more torque if not 50. It depends where it was slipping but hp may not change much since its at high rpm where its less likely to be spinning. Speculation aside it will be interesting to see the result with the DRs.
Old 10-22-2009 | 06:38 PM
Red 9's Avatar
Red 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond repute
Originally Posted by bmoores
Well we had a little trouble on the dyno this evening with wheelspin. 4th gear pulls. We tightened the car down a few times but just couldn't get it to put all the power down without wheelspin. .
I think this is a big issue once serious power is being made.It is one reason I am sceptical about so many numbers seen.
bmoores's Avatar
I'd agree Mike I'd say about 25hp and 50-16tq still on the table. But who knows? It is what it is. Car goes like stink. We'll see what Todd K. thinks after we get a good dyno and see how to proceed with getting more power safely.
Old 10-22-2009 | 06:42 PM
MBailey's Avatar
Hey Ben, if you can pick your time try early fri or sat. Air should be cool and dense like it was at the mile.
Old 10-22-2009 | 07:06 PM
topgun's Avatar
topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !
Dyno numbers don't mean much...u went 200....that counts more than the dyno numbers. Your car rips
Old 10-22-2009 | 07:25 PM
BlownVette's Avatar
BlownVette has a spectacular aura aboutBlownVette has a spectacular aura aboutBlownVette has a spectacular aura about
Not sure if you are dynoing in RWD or AWD, but if you put someone (x1 or x2) in the back seat it might help to get some weight over the rear axle to help with the wheel slip.
Also, when I had twin-side-mounted intercoolers I used to use two high-speed-electric leaf blowers directed at the intercoolers to better replicate actual driving conditions and get air flow across the intercoolers. Regular type fans, even the squirrel cage designs, don't seem to get the job done.
Old 10-22-2009 | 07:28 PM
Dr_jitsu's Avatar
This is 6speed, nothing is drama free
As mentioned, you did 200 and will break 6 seconds in the 60-130 that is what really matters, however you should be close to 700 on C 16 and 1.5 bars.
Old 10-22-2009 | 07:43 PM
Swole Powell's Avatar
Swole Powell Is a GOD !Swole Powell Is a GOD !Swole Powell Is a GOD !Swole Powell Is a GOD !Swole Powell Is a GOD !Swole Powell Is a GOD !Swole Powell Is a GOD !Swole Powell Is a GOD !Swole Powell Is a GOD !Swole Powell Is a GOD !Swole Powell Is a GOD !
Nice numbers! Sound like you and chris were on the dyno at the same time!
Old 10-22-2009 | 08:12 PM
bmoores's Avatar
Absolutely Tom. There were a few inquiring minds .
Sean, dynoing RWD with the cage its hard to get someone in the back now We had a sufficient fan setup from what I could tell. We'll see what we can work out this weekend.
Sean, I'm thinking we'll be quite a bit closer to 700 if we can get a clean dyno run. We'll see what happens though.
He called me and told me the numbers .... reminds me of a song I know ........ Just kidding I bet its going to be a lot of fun.
http://www.youtube.com/watch?v=9F444CELomo
Old 10-22-2009 | 08:15 PM
I will take the shirt over the dyno numbers any day! But I hope we done hear any boom's
Old 10-22-2009 | 08:23 PM
bmoores's Avatar
With Mr. Nenni behind the computer I don't think we will. It all depends on big bro's ability to think with his brain and not his right foot!!
Old 10-22-2009 | 08:45 PM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
definately interested in the new numbers i would of thought u were putting down more power with the k24's n how the car ran.
Good luck ben whos dyno were u on? Driver Source?
Quick Reply: Preliminary Dyno Numbers K24/20g's
