Blew my motor! :(
Old 10-29-2009, 12:40 PM
Kato's Avatar
Kato is just really niceKato is just really niceKato is just really niceKato is just really niceKato is just really nice
Make sure you grab an oil sample and send it in for analysis at Blackstone Labs. It costs about $23 and will help determine the exact cause of the issue. I just did it with the oil from my spun rod bearing (confirmed given metal content in oil-I think, LOL).
I attached mine for people to take a look at.
File Type: pdf
  #167
Old 10-29-2009, 12:49 PM
jhuang25's Avatar
jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !
I'll definitely do that kalon. Thanks again for all the tips. Wish you the best on your build bro, we'll have to get together once the car is done so you can lemme sit shotgun!
  #168
Old 10-29-2009, 01:36 PM
007-911's Avatar
007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of
jhuang25 Good luck man, remember everything happens for a reason. I really believe in that. Who knows you might end up with a TT Gallardo next
  #169
Old 10-29-2009, 01:45 PM
jhuang25's Avatar
thanks brutha... TT Gallardo would be insane! I do believe the next one will be better, that's for sure.
  #170
Old 10-29-2009, 05:44 PM
BLKMGK's Avatar
Originally Posted by DaveM@EPL
I think there is a small misconception of how the water injection system actually works. The pumps operate at 160psi, and are spraying through tiny nozzles (1mm or less). What you basically end up with when these things spray is a mist, not so much a stream or jet of water. It atomizes with the air almost instantly, so really it is spread throughout the cylinders as effectively as the air itself.
Well, carburetors also work this way. However they have wall wetting issues and other problems to contend with. Run enough meth and this will begin to become an issue with that fuel as well.
Food for thought and why I prefer not to run tons and tons of the stuff. It DOES help and it was providing fueling for this car. Fingers crossed that a tear-down provides some clues.
  #171
Old 10-29-2009, 09:00 PM
RickEager's Avatar
RickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond repute
Originally Posted by jhuang25
On the way to Ca. Speedway on Sun to run the POC event, i blew my motor!
I know the feeling my friend... Been there... done that...
https://www.6speedonline.com/forums/...hp?albumid=707
Life will get better!
  #172
Old 12-22-2009, 02:42 AM
aroonkl's Avatar
aroonkl is a jewel in the rougharoonkl is a jewel in the rougharoonkl is a jewel in the rougharoonkl is a jewel in the rough
Hi Rick , Jhuang,
Any update on problem engine yet? Thanks.
  #173
Old 12-28-2009, 05:14 PM
vividracing's Avatar
If you want a FREE stroker kit, hit me up
  #174
Old 12-28-2009, 08:19 PM
colorinc's Avatar
colorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond reputecolorinc has a reputation beyond repute
ill take one
  #175
Old 12-29-2009, 12:51 PM
robertp's Avatar
robertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud of
I am not feeling warm and fuzzy with BBI. I sent my friend over there with his F360 and they totally messed it up. They did not even service the car, they sent it to another shop for all of the work (which was news to the owner). $8,000 later and it still has the check engine light on and they did nothing to rectify it.
COBB Tuning
01-05-2016 07:06 AM
alpha motoring
10-02-2015 12:04 PM
metzkaro
09-30-2015 12:48 PM
Quick Reply: Blew my motor! :(
