Blew my motor! :(
Yeah, sucks so bad bro. No cels at all, the car has been running flawlessly. I purchased the Greddy Profec II from Vivid actually. I was hitting like 1.35 bars of boost on 91 + meth on both my recent races as well as on the dyno. AFR's were in the low 12's... but in this situation, I couldn't have possibly hit more than .8 bars based on my rpm and gear. I wasn't close to redline, it was a routine getting on the freeway type of situation.
sorry to hear about it..
mark
2001 996TT 3.6L and stock ECU
Sorry to hear about your misfortune. It's something noone ever wants to happen. I think Art and Betim will steer you in the right direction. Art and I spoke about optimal power levels etc and he has pretty good perspective on the different power levels.
According to some experts...this shouldn't happen! I feel your pain . You need to open her up see whats damaged & take it from there. A must is rods & oil pump. the rest is optional. The damage to the motor didn't have to happen that particular day, it could of been accumulative over time. I'm sure BBI will take care of you.You might want to weigh your options on the rest maybe head work, cams, crank it all depends on what you want & your budget...Good luck. This is sad to hear...
Proto did not supply the meth kit... but Todd was on hand when we were on the dyno at BBi, and looked at everything closely and specifically told me that he didn't see a need to change anything to my file after we added meth. He was datalogging the dyno pulls on site... so I did assume that everything was looking ok.
Thanks Ben! quote from Betim this morning, "your next engine will be bullet proof". haha.
Thanks guys. It's funny because I tried to do everything right with this build, going with a well respected tuner, adding meth and was at a very conservative power level for a stock motor(550 rwhp)... but in the end, it might've been something like an oil pump busted on me and everything is up in smokes.
Dude, I came down all the way from Cali and you did not even come down to say hello?? How the heck is your shoulder now?
J , im willing to bet that your oil pump took a ****. especilay since you said you heard metal grinding them bam...
that sux, sorry to hear. now you just a slight motot build, and unless your going for BIG power keep it simple, rods gasket , headstuds , and call it a day.
Sorry to hear this. I'm not sure I am reading your datalog correct but did it say 36 degrees timimg advance at 7k rpm? I know zip about meth tuning but I know you have 10 degrees minimum on my tune, maybe more. Good luck in the future and once again sorry. Kevin
Your about 6-14 degree hotter on timing then I am on 93+ meth. c16 doesnt even need as much timing as you have in some spots.
Are you running 100% meth or 50/50. Would be interesting to see the piston tops or plugs...
How much racing do you do? How much dyno time did you have? Do you always run up to 7300-7500? I was just reviewing you timing logs and happen to notice that you seem to have a LOT of timing up top for only 91, even with Meth. I run 93oct and 100% Meth and my timing is not that aggressive. I only ask, as this could promote some bearing wear and possibly other things? I realize that you were just cruising onto the highway, but the damage could have already been done. Also, do NOT mistake this as stab at yur or ANY tuner, this could be learning curve for all of us that have meth and think we are safe, if in fact it turns out, that your oil pump is fine.
Sorry, that's ignition angle you are looking at. The timing was like high 13's to low 14's in the high rpm range.
Sorry to hear about your loss man
Ignition Angle refers to the amount of timing. 13s/14s would be 6-7* below what you should run on pump gas as far as timing goes. Now maybe A/Fs would be in the 13s/14s, but even then that's ENTIRELY to lean for a FI car.
