why can't I fill my gas tank all the way up?
Old 03-05-2010 | 09:17 PM
Stevebuc's Avatar
Stevebuc is infamous around these parts
Thanks for the tips on this one. I am a new TTer and it has been driving me crazy that I can't get the tank full. Was getting ready to have the fuel guage checked.
  #32
Old 03-05-2010 | 09:43 PM
Frissen's Avatar
Frissen has much to be proud ofFrissen has much to be proud ofFrissen has much to be proud ofFrissen has much to be proud ofFrissen has much to be proud ofFrissen has much to be proud ofFrissen has much to be proud ofFrissen has much to be proud of
My 996TT takes a full tank but spills a little at the of fueling, also, does the 986 takes more fuel in than the 996TT?
  #33
Old 03-06-2010 | 12:00 PM
art4iza's Avatar
art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !
I'm still having the same issue at any position of the nozzle. Any ideas?
  #34
Old 03-06-2010 | 12:33 PM
TurboCab's Avatar
TurboCab is infamous around these parts
The one that works for me is turning the nozzle 90 degrees. Works every time
  #35
Old 03-06-2010 | 01:30 PM
Stevebuc's Avatar
Tried the 90 degree (at 9 oclock) this morning and work perfect.
  #36
Old 06-07-2010 | 11:48 AM
jimmy k's Avatar
jimmy k is a jewel in the roughjimmy k is a jewel in the roughjimmy k is a jewel in the roughjimmy k is a jewel in the rough
Originally Posted by robertp
I have hadthe issue on seceral other p-cars but not my 05 Turbo S. I talked to seceral other Turbo S owners and they confirmed they too did not have the issue. As I stated before, the problem was fixed with the Turbo S.
I just had this problem on my Turbo S. I hope it was just a glitch. I'll report back after my next fill up and keep the 9:00 trick in my memory bank.
  #37
Old 06-07-2010 | 12:09 PM
MY996TT's Avatar
MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !
And don't use the fastest click on the nozzle, use the slowest or the middle (if there is one).
  #38
Old 06-07-2010 | 01:53 PM
buddyg's Avatar
I have this problem as well Porsche should have a fix for this. It is annoying but I am going to try the 9 o'clock suggestion next time.
  #39
Old 06-08-2010 | 12:03 AM
TTHunter's Avatar
TTHunter has a spectacular aura aboutTTHunter has a spectacular aura aboutTTHunter has a spectacular aura about
Kevin at UMW explained to me that once the tank is half empty it calculates the fuel level instead of reading a float. This was his explanation after my fuel suddenly went to empty after his flash. Once I filled it back up, no problem. He did not say anything about not filling it up with the ignition on. I'm not grasping how that would mess anything up.
Somewhere between a right angle and up side down for the gas nozzle seems to work for me for getting all whopping 16 gallons in there.
  #40
Old 06-08-2010 | 05:35 AM
alex55's Avatar
alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !
from what i know there is no problem if you are putting gas in the car with the engine on.
  #41
Old 06-08-2010 | 10:12 AM
Turbo Fanatic's Avatar
9" O'Clock works every time. I've come to believe that the Porsche has a defect in that the vapor recirc system doesn't seal properly until you turn the pump to the 9 position. You can see that it seals in that position and fills up.
Engine on seems to help, but isn't as effective as 9 o'clock
  #42
Old 06-08-2010 | 10:27 AM
2muchtime's Avatar
2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute
mine has always been an issue, 9:00 doesn't work for me straight upside down, once it clicks off it is full, I can actually see gas at filler neck? Wonder why there different??
  #43
Old 06-08-2010 | 01:32 PM
harkerdude's Avatar
harkerdude is infamous around these partsharkerdude is infamous around these parts
I don't know if they really fixed it or not.
My father's 2010 997.2 C4S has the same problem so I had to teach him the 9 o'clock method.
  #44
Old 06-08-2010 | 02:17 PM
Nikolas's Avatar
Nikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant future
It is a safety requirement for all gas stations.
  #45
Old 08-18-2010 | 10:10 AM
Drew's 996's Avatar
Drew's 996 is infamous around these parts
I've got this same problem. I'll give this a try and see what happens!
Quick Reply: why can't I fill my gas tank all the way up?
