What is the difference b/t Agency Power IC, and other much more expensive ones?
Old 08-07-2010 | 03:31 PM
RiA's Avatar
RiA
RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !
Originally Posted by ard
I think many vendors play games with "raw materials source" versus "where final assembly is done".
There is almost no regulation on what a vendor can say about where it was 'manufacturered'... Indeed (and this is just a hypothetical), Vendor A can claim their product is "built in the USA by Vendor B", and Vendor B can order parts from china all day long, and slap a 'made in USA' label on them- maybe add a few items to the kit, or post process them. Nevermind that Vendors A and B are all one common ownership/management. (This is JUST hypothetical, not making any accusations about any of the board sponsors.)
wink,wink - nudge, nudge - know what I mean, know what I mean.
  #62
Old 08-07-2010 | 04:40 PM
FAST FWD's Avatar
FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !
Markski -
I *really* appreciate that you are posting some real data. Impressive results.
Jon
  #63
Old 08-07-2010 | 04:50 PM
Originally Posted by FAST FWD
Markski -
Jon
I have more but Do not want to take over the thread lol
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
  #64
Old 08-07-2010 | 08:03 PM
earl3's Avatar
earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !
This thread was dead, do it!
  #65
Old 08-07-2010 | 08:36 PM
AWD Motorsports's Avatar
AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !
We buy or cores from Gerhart the owner of Bell Intercoolers... We weld them in house and pressure test them to 35 psi...
Here are our findings on our 3.5's vs stock... and thats still using stock 1.8" inner diameter hose connections... (we make them for both stock hoses and big mouth 2.5" piping).. on a 18g car peaking 1.15 bar on pump gas that dynoed 564rwhp. same car nothing else changed...
markski
Uploaded with ImageShack.us
Thank you.. As i read thru and was about to post i found this.. all intercooler testing we have done in the past was based on AIT's. PERIOD.. What does the car start at and what does it end at.. I am not talking 1 gear pull on the dyno with 200mph wind.. Im talking.. Dead stop to top of 4th gear in the 1/4 mile or from start to high gear on a roll.. What it does pulling 1 gear on the dyno is meaningless..
As far as if are all intercoolers Equal.. I can spot a chinese core from a mile away and YES they are much less efficient.. We just did a 1200hp supra with 5" Chinese FMIC that was seeing 180+degree AIT in high gear.. Swapped to Garrett 5" and brought the AIT all the way down to 130's.. The owner couldnt believe it.. Proof is in the LOGS... 50 degrees is NIGHT AND DAY..
Mike
  #66
Old 08-07-2010 | 08:37 PM
Originally Posted by Prche951
Does anyone even sell any with overseas cores. I thought all the cores here were made in the US.
More of them than you know are Chinese Cores.. The fin Density is the 1st dead giveaway,, Giant wide U shaped fins vs much more dense tight fins..
  #67
Old 08-07-2010 | 08:48 PM
Here is an idea..
Garrett Cores
Chinese JUNK
  #68
Old 08-07-2010 | 09:06 PM
bbywu's Avatar
I think the most useful information are two calculations: thermal efficiency and pressure efficiency. IATs alone are helpful, but the number itself is influenced by other factors. Similarly, "x% larger core" "x% better flow" aren't terribly helpful.
Thermal Efficiency (percent) = 100 x (Tin - Tout) / (Tin - Ambient)
...will give us an idea of how well the core does. Similarly, pressure efficiency will tell us how well the intercooler's flow parameters are.
  #69
Old 08-08-2010 | 07:33 AM
Neil A's Avatar
Neil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud of
When i fitted my 3 1/2" Bell cored coolers and intake pipework recently i did before and after datalogs along the same stretch of road, i drove normaly to get there then cruised for 3 min to let temps drop ,then did three 3rd gear pulls with 4 min between each one. We found quicker temp recovery, lower peak temps and smoother boost.
I know without going hard into 4th and 5th gear you cant fully test a cooler ,but i hope to be doing those tests in the next couple of months on an air field.
  #70
Old 08-08-2010 | 08:20 AM
landjet's Avatar
I would like to see these kinds of comparison tests done by someone like Excellence Magazine who have the deep pockets to pay a team of mechanics to spend a couple of days at the track changing from one intercooler to the next, and documenting all the most pertinent performance data so the layman could make an informed purchase. It could be a monthly feature which could compare intercoolers, turbos, intakes, plenums, shocks, etc. Anyone know the people at Excellence?
  #71
Old 08-08-2010 | 10:04 AM
VAGscum's Avatar
Here is an idea..
Garrett Cores
Chinese JUNK
So the difference is the chinese ones look blurry and out of focus when photographed
All joking aside, the Garrett ones look like they have alot more fins that probably make them more efficient.
  #72
Old 08-08-2010 | 10:16 AM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
what if the most important factor to a heat exchanger?
Surface area.... Many properly placed fins = much larger surface area
then after that comes flow, pressure drop efficiency(related to surface area)
  #73
Old 08-08-2010 | 10:26 AM
Dr_jitsu's Avatar
I have the protomotive 5 inchers and I run my car hard in the brutal heat and humidity here and my IAT's are almost always under 120.
  #74
Old 08-08-2010 | 11:47 AM
ard's Avatar
ard
Exactly- and this is the hardest factor to evaluate. (it seems for vendors and mfgs...) As cjv pointed out you just measure temperatures. Air pressure drop throught the IC will not capture the impact of these fins since the fins are outside the intake path.
But if your metric is "we bolted these on and did a dyno run" or "...did a 1/4 mile" you will not fully capture the performance in a heat soaked, multi-run, track duty type of environment.
A
  #75
Old 08-08-2010 | 01:01 PM
earl3's Avatar
A
yup, gotta get them to steady state if that's the environment you're after. A dyno or 1/4 mile run is just showing transient response which isn't too hard to show gains; but if that's what you're into...
Mike@AWD, I've been trying to source a proper size Garrett core for the 996 but with no luck. They once offered a 14x12x3.5 core that would have worked by trimming a couple rows off but it seems they discontinued it. Do you know of any prospects? I'd take Garrett over Bell from a thermal efficiency standpoint unless the core was sitting in front of a radiator (which we don't have to worry about). Oh and sorry for the blurry China core pic, though I'm glad someone is using it I can take more with a flashlight behind it -it isn't pretty.
Also realize that the stock and GT2 cores have about 1 1/2 in^2 of completely open flowpath (non intercooled air!) I have no idea why AKG would do that, unless the coolers fell short in meeting flow requirements.
Heres a stock 996 cooler next to a GT2/997 core. The density isn't bad but the open channels, 2" core and endtanks leave something to be desired.
