A Special Thanks To Tony@EPL and Chris@AMS
Good thought... But thats not the case here. This file is for the injectors + 5 bar and is running in many cars. Im sure its somthing simple and his shop will figure it out quickly.
when i hit the throttle and car bucks and cuts fuel supply and feels like i hit brakes for a second..but it recovers.
I sent you a detailed email , Please help.
Tony , they checked for boost leaks could not find anything. The car is bucking under boost at 4k rpms, also got misfire codes on cylinder 5,4,6 and Total Misfire
You likely need plugs and coils. On a modded car, 5000 miles is about it for plugs. When you mod a car, it tends to get hotter and cook the coils. You probably need a couple of those too. Tony will tell you what to get.
PelicanParts.com
09-08-2015 03:11 PM
