best 1/4 mile for K24?
The car had about a 2.0 60 foot and I bet you the wing is worth at least +1 tenth.
This is a race car....but NOT a drag car by any means.
I ran 11.5 on a 996tt full weight.. at 1.2 bar.
2001 996TT 3.6L and stock ECU
You'er correct. Meth + minor weight reduction. This could have easily been done with 100 oct as well, so in my opinon it can be replicated with out meth.
How much did Davia pay you to advertise his car.
Peter
That wing is probably worth more than just a tenth, but some MPH as well. I'm torn between retuning my K24's or getting the AMS K16's.
Tony what would you advise for the following:
550 awhp (probably 520-530 on a mustang dyno)
Pump Gas (no meth)
Quickest Spool
I don't want to HAVE to refill tanks or find race gas, but get the quickest spool and power possible anytime I want it (yes I'm lazy).
Pump Gas (no meth)
Quickest Spool
whats the most power you can make on straight k24s ???? pump/pump meth and 100 oct and at what bar?? i ran an evo with gt35 the other night and won by a car and a half at about 1.1 bar 93oct tune of unknown origin.... im tryin to figure out if i can gain more with a diff tune or to just swap turbos and other parts
Pump Gas (no meth)
Quickest Spool
Pump Gas (no meth)
Quickest Spool
Seems like it would be better than straight K24's. K24's are a little flakey
in their performance. (Peaky, then die off)
Pump Gas (no meth)
Quickest Spool
Pump Gas (no meth)
Quickest Spool
That depends on the tune, mine do not die off at all. And with straight pipes the power curve is ideal for road racing, my dyno pulls hp increase all the way to red line which is the best way for road racing. A little less torque as well, which makes the car more driveable.
They just spool too slow, and need a bit more power. I really like the AMS K16's, I just don't like having to go get race gas and stuff. But that's likely going to be the best route though. Do 18g's spool faster than reg K24's?
What's the highest safe rev limit on around 550 whp stock engine? I know I'm jumping around but it all ties together for me.
With k24's or k24/18s there really isnt any need to rev passed 6800-7000. Most of our files have the rev limit set at 7250 or so.
There is on the road course. 2nd gear could be made a lot more useful with a bit higher rev limit on it. After having driven Al Norton's car with 8k rpm it's hard not to want it. But his motor is built.
BlackMarketRacing
12-08-2015 01:49 PM
BlackMarketRacing
12-03-2015 10:46 AM
