Who is cheaper and better for k24/18 upgrades w/reflash?
Are you running 75mm TB also?
i know proto makes a y pipe that you have and that y pipe replaces the Upper intake plenum(fresh air to turbos) but i was talking about the piece behind the TB, air goes through Proto y pipe then to Throttle body then to the stock T plenum or replaced by the IPD plenums?
Proto has a plenum for after the TB like IPD?
Cool, hope you'll like it. It is a big improvement cruising around town (it stays in 4th).
you know, he could go for the ultimate upgrade, loosing a few limbs, since he does not need to shift and there is no clutch. One leg and one arm would do it, about 60 lbs.
I have a PSI loud exhaust w/100 cats DV's Silicone hoses and Bmc air filter
Should i do 5bar FPR or 60lb injectors?
few guys they recommend injectors than FPR
and who should recommend for reflash and 18gs?(you can pm on that)
thank you
Boston is so close to CT that you should really consider going to EPL. I'm planning a trip up there, but just haven't had the chance.
Billy,
I was thinking the same thing - you should get to know EPL for your tuning. He's close to you - I go there from NH all the time and it's not a bad drive at all.
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
2022 Cayenne White
Feelgood MD
03-24-2016 09:35 AM
faiz
09-02-2015 08:43 PM
ECS Tuning - VW
09-02-2015 09:03 AM
