Startup issues with the clutch pedal
Old 11-20-2009 | 11:43 PM
c2scanada's Avatar
c2scanada is infamous around these parts
I currenty have to pump the clutch several times before I can get the car to fire.
Is there a microswitch I have to clean or replace ?
Is there away to disable this feature ?
thank you in advance
Old 11-21-2009 | 03:52 PM
joe731's Avatar
joe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to behold
There is a switch. I had this problem after the car sat through the winter. It's hard to miss if you stick your head under that dash. Sits high near the top of the pedal arm. I jiggled (tech term ) mine a few times and it has not given me a problem since.
Old 11-21-2009 | 03:59 PM
c2scanada's Avatar
Thank you I will give it try
D
Old 11-21-2009 | 04:04 PM
deputydog95's Avatar
deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !
I had mine disabled when I had the clutchstop installed.
Old 11-21-2009 | 07:24 PM
c2scanada's Avatar
How do you disable that feature ?
D
Old 11-21-2009 | 07:47 PM
They installed a jumper between the switch leads. It makes the car think the car has the clutch in.
midwestamv8
Audi
09-09-2015 11:53 AM
orbelo
08-30-2015 12:26 PM
magoochi
08-23-2015 05:54 PM
cerbomark
08-22-2015 12:50 PM
Quick Reply: Startup issues with the clutch pedal
