Rear Dog Bones on a Budget
Well.... Here we go.. i'll give you the list
(4 or 5) 6061-T6 or 6061-T6511 Aluminum 1" OD Rods (lets say 12" long / each)
(1) 37/64" Drill Bit for the 5/8-18 tap
(1) 12 mm Drill Bit for the ID of the spacers
(1) 5/8-18 Tap LH
(1) 5/8-18 Tap RH
(4) FK Rod End JMX10T or Aurora AM-10T (5/8-18, 5/8 bore) RH
(4) FK Rod End JMXL10T or Aurora AB-10T (5/8-18, 5/8 bore) LH
(1) Lathe or a friend with a Lathe...!!
(1) Milling Machine or a friend with a Milling Machine!!
or you can get the aluminum rods made to spec with 5/8-18 RH/LH thread. There are many sites on the internet for this.. usually these goes from approx. $10-15/piece
(1) 5/8-18 Tap LH
(1) 5/8-18 Tap RH
The most time consuming part of this job is finding the components with the proper specs. Then finding a company that will sell to you and just 4 of them. So many different grades, strengths, and bearing types of rod ends. Also parts for a track car may not be satisfactory for a daily driver that sees chuck holes, railroad tracks, bumps, extreme changes in pavement from overpasses, etc. rain, snow, road grime, brake dust. Track cars may stress the components more but a street car will beat them up and pound them more.
I ended up taking off a stock dog bone measuring it, and basically duplicating it and making it adjustable for length using parts from race car parts suppliers. 5 different suppliers to find the parts I wanted and needed. These are a relatively small volume item and that's why those that sell them get $1000/4. The numbers aren't there to order rod ends and jam nuts by the 1000s.
The ID will be 12mm to match the OEM bolts and the OD will be to fit the 0.625" bore diameter of the rod end. The misalignment bushings should fill a gap of 1.5" total.
Attachment 397198
Attachment 397198
Where to get bushings prefabbed? I don't have access to fancy tools. The rest of the parts seem easy enough to source. If anyone lnows please pm or post
hmm.. not sure, maybe a custom order to fit the size. These are the ones i made using 6061 T6 Aluminum Attachment 397289
Could you make me some?
I also noticed they make metric joints but nobody has 6inch tube threaded metric
Walorus
08-18-2015 01:39 PM
