Who uses something other then 0w-40 Mobil 1 and why
#47
Yes, but it's been a while. I used to use it in my RX-7's (all three generations) and can say one really great thing about it. Mazda's rotaries all use oil injection in the rotor housings to lubricate the surface that the apex seals ride on as well as relying on some blow-by from the oil seals on the rotor side to lubricate the side seals. This inevitably results in some carbon buildup etc on the rotor and side housings. It's rarely an issue in a torn down motor, sometimes causing side seal sticking, but the street and track engines that had been run on Redline had a lot less carbon built up in them. I can't compare to other synthetics because a lot of older Rotorheads had embraced a peculiar religion that running synthetics increased the rate of carbon buildup. Redline was magically immune, apparently...
tita1989
08-17-2016 03:13 PM
