Those that have done the K24/18G upgrade.. Questions
#31
WOT noise restriction ouch
im very familar with noise resriction in the Atv world at the dunes some places are 93db and some are 97db but thats a 300rpm or so just 1/4 throttle like 16" back and at a 45* angle had to spend about 500$ for an exhaust on my big bore stroker bike(2stroke) to get it to pass so i don get a 380$ ticket and the camps next to me i watch them pull the packing out of their silencers for the hell f it n ride around straight piped *shakes head*
Any info on Db level that is tolerant?
#32
+1^^^ Basically what John said. I have had the 18G's for a year and a half or so and my cars runs and drives perfect at the 575-600whp level. I don't think you would regret the 18G's, but regardless of which turbo you went with, you can pretty much count on a new clutch as your TQ will increased considerably. It sounds like you want to track a little, so I highly recommend an EPL tune and AMS's billet K16's. Pretty much the same power as 18G's and quicker spool for the road racing.
#33
#34
see thats the thing here he does't need topend power he needs fast spooling smooth power
the 18g upgrade makes sense because he starts with k24s
car with less power but flat torque curves n smooth power curves will be faster ona track and more stable in the corners peaky power can upset the balance mid corner at 100+ pretty easy even if you have some bad *** suspension like the OP has
#35
rediculous it is but you can do it just gonna be a heavier exhaust with more restriction.
what i would recommend is stay with a BMC/K&n stock style filter stock style airbox maybe even one of those dual snorkle setups i seen recently.
5Bar FPR is plenty of fuel, Proto, UMW, EPL great choices
you will blow through a clutch if you bump the boost up ona larger set of turbos pretty easily, even stock turbos witha flash n exhaust people are slipping. Do upgrade the wastegates, teres more then one car floating around that has rebuilt motors cause of ****ty wastegates failing.
and whoever your tuner is discuss Timing and not running alot of it to make your motor last longer.
#36
I never said that they made the same power at the same boost. They have however, put down the same or similar performance numbers as an 18g equipped car, and that is still impressive. The OP is looking for a quick spooling turbo. I thing the 18g is an awesome and proven turbo and exactly what he needs, but this new Billet K16 is still a pretty impressive alternative, if he is looking for explosive "out of the corner" power for the track.
#37
Lots of great feedback from you all.. Thanks guys..
Here's what I think I will end up with:
Tune (to be determined still)
Exhaust (not sure yet)
Billet DV's
K24/18G's with 1 bar actuator wastegate upgrade and ported hot side
BMC panel filter
Dual snorkle intake setup from Vivid (already put my deposit down)
ported stock headers
5 Bar FPR.
I'm still talking to my shortlist of Tuners to see who can give me:
switchable maps for 91 octane and 100 octane (maybe auto switching/sensing)
left foot braking (brake boosting)
ability to go quickly back to stock if necessary
HAS to pass California emissions
Good power and torque increase without being near the edge (no blown engines thank you).
Thanks again for all the valuable feedback.. Great Forum this is...
Billet DV's
BMC panel filter
5 Bar FPR.
#39
Thanks for jogging my memory on this one..
#40
Hang on there Jack Russell.....isn't this all really a moot point....if you really must pass the db issue, and a stock gt3 and z06 fail, you are not going to find any aftermarket exhaust for your car that will pass.
If that is true, I'd rethink my goals, as the car simply will not perform close to potential without a free flowing [read LOUD] exhaust.....
#41
I'm going to be moving up to the 18g myself real soon, so this thread was very informative. Keep us posted on what you decide. Any need to upgrade the MAF or injectors with the K24/18g setup (I have stock injectors, airbox with K&N, and 5 bar FPR)?
#42
You can get away with JUST a 5bar, but will be limited in power. Injectors will give you some more "room" to grow. I have 18g's, Injectors, stock airbox, stock MAF, stock air filter and stock piping and intercoolers and my car rips. Sounds like all you need now is the turbos?
#44
Billet DV's
BMC panel filter
5 Bar FPR.
Billet DV's
BMC panel filter
5 Bar FPR.
Be careful with "self adjusting tunes". Most are running timing too aggressive for track use and letting the knock sensor sort things out. This doesn't mean a car wont respond well to higher octane... It just means you shouldn't rely on the knock sensor to know what octane is in the tank.
On my 550 HP 944 Turbo, I had the entire system from headers, downpipe and entire system to the muffler (but not the muffler itself) Jet Hot coated with their 2,000 degree coating.. One of the benefits of the coating that I found out later was that it quietened the system down (less resonance) and I never had noise problems at Laguna.. Maybe that's the answer !!! buy a 3" system and have my headers etc coated and see if it helps with the noise..
Good Luck!
#45
