Need tire pressures for Hoosier Slicks
Hoosier Tires
What year & model car?
What is the car weight with driver and fuel?
What range is the horsepower in?
Is the suspension stock?
What are your alignment specs?
Are you running bias slicks, radial slicks or dot track tires R3S03?
If you are running slicks what compound?
Are you filling the tires with air or nitrogen?
Which track are you setting up for?
What do you think the temperature will be at the track when you run?
All of these things will determine what pressure to start with.
You could also buy a tire pyrometer and take tire temps at the track and adjust the tire pressure that way. You may not get the maximum potential of the tires but the pressures will be matched to your set up.
I change on my Cup Car the alignment and/or tire compound depending on which track I'm going to.
04-28-2022 12:38 AM
RallyBird
10-07-2015 01:20 PM
horsepowerfarm
09-10-2015 06:09 PM
