1.2Bar wastegate Kit
Why do yo want 1.2 bar springs?
turn up your 1 bars and you get the same thing..... the 1.2 bars may be too difficult to dial in... I had them about 4 years ago...
One solution is use a Greddy boost controller... then you can dial it in exactly where you want it...
2001 996TT 3.6L and stock ECU
I would use a gauge to check if they open up at the same time.... then turn it in clockwise 2 turns... you should not have a problem with that...
stay away from 1.2 bar... when it gets hold you will be boosting .2 bar more...
Some tuners do not use a EBC but its a wonderful thing if you know what to use it...
Is it possible the ECU has been tuned to prevent an overboost? It has an e-throttle so that safety could be done I suspect. If they did this for 1.2...... Have you spoken with EVOMS about this?
My tuner is EPL, and i think Tony has tuned it to 1.4bars, because sometimes i can see it holding up to 1.3bars in colder days, but i never saw 1.4bar yet, i'm sure its the wastegate kit not the tune, its just a pain to set them up where you want.
04-28-2022 12:38 AM
