Two blank buttons on rear center console
That's what I did... Pull out the ashtray and there are a couple of plastic torx screws underneath. Unscrew those and the console with the switches pops out. Wire it up there and then slide the circuit board under the center console
To the best of my knowledge, Homelink is only a 2005 option (as well as perhaps 2004). Earlier models don't have it, nor was it available as a special order option.
My 04 Cayenne had Homelink and I was disappointed that the 03 911 Turbo didn't? This is a great idea and I will be using the blanks for the garage doors. Thanks for the info.
Driver's side middle button: rear spoiler manual control. Passenger side bottom button: rear window wiper. Driver's side bottom button: I have no idea! (mine is also blank)
On my right side, I have lower = cabin lights (turns on the dome light, map lights, door lights with one click)
My rear wiper doesn't exist anymore, so that button is coming out and the garage door opener button is going in.
That blank spot is reserved for the optional floor lighting switch.
