IAT's: What is the Normal Range?
Here are some IAT temp in degrees celcius with German aftermarket intercoolers
With GT2 intercoolers IAT was 13 degrees celcius higher.
My car has 550hp at the cranck and 1 bar boost.
Colom B is RPM
Colom C is IAT (degrees celcius)
Colom D is outside temp.
Colom E is speed.
Next month we will do some testing with hopefully better IC's
Colom B is RPM
Colom E is speed.
I'm sure these are IAT without boost,on full boost they will be much higher.
yes just cruising on the hwy, clutch not broke in yet. engine at operating temps, after stop and go back on hwy; on avg 5C gap between IAT and ambient. will post figures using several 180-200 kph pulls when get the chance.
I have some data with EVOMS ICs. Sorry I did not pay any attention to IATs until I upgraded the ICs. My car runs 4-6 degrees C above ambient whether its hot or cold. In a max boost run it will get to about 20-22 degrees C above ambient. This is a 4th gear pull.
At the Texas Mile this year in October, I was watching my IAT's to see what they were. I don't remember what the ambient temp was but it wasn't 50-60f degrees out. Mine were in the 95 (start)-105f (finish) range at the end of the mile. I do have Meth injection, but vividracingtx also did this with bigger intercoolers and piping and got roughly the same results. This is 6 gears, at 1.3bar of boost, for about 25 seconds.
A concern I've had with meth, and one I'm not sure is valid, is that the meth mixture might land on the sensor and as it evapped cause a false low reading. I'd be interested in the thoughts of others on this. When I instrumented my Supra I was also careful to use a Teflon plastic insulator so that the IAT wasn't heatsoaking from the surrounding intake material.
Anyway, nice to see folks posting up information on temps with conditions and different intercoolers! Since everyone is taking the temp the same way through the ECU it ought to be comparable....
I just took the turbo for a spin (useless!). It is 12deg out and my IAT was averaging 23-28 degrees. This was with the engine at operating temps and watching it in boost quite a few times. I still have stock intercoolers and piping, so I think with the addition of IC's and piping, my IAT's would be awesome!!!
Have not collected any IATs with my 03 Turbo -- that I have handy -- but collected it for my 02 Boxster. 135F in 116F ambient temperature. Southern AZ. Summer. July.
(FWIW, coolant temperature reached 226F and stayed there. Engine compartment fan was running even at speed.)
Sincerely,
Macster.
Sincerely,
Macster.
Im using the brockway aswell. wish it had more than one custom mode screen or displayed 4 instead of 2 params at once.
did 3 pulls back to back 2nd gear thru 4th gear to 6k rpm. Ambient 17C. IAT 32C
immediately onto highway, 2 pulls, 6k on previous gears up thru 5th to 5k. IAT 29C.
BTW did you get the LED shift light as well? The wire and bulb were included but not the green connectors in the instructions. Do you know if we are supposed to source these independently? TIA
WheelB
Other British Cars
09-15-2015 01:51 PM
WheelB
Other British Cars
09-15-2015 10:40 AM
