4 way adjustable Moton shocks!
Old 12-11-2004 | 01:58 AM
HKE46Boy's Avatar
HKE46Boy is just really niceHKE46Boy is just really niceHKE46Boy is just really niceHKE46Boy is just really niceHKE46Boy is just really nice
4-way damper, officially released
The New 2005 Moton 4-way damper, now available and officially released...... Moton is proud to announce the new 2005 4-way adjustable dampers. It has taken us over 2 years to develop and test this new damper system on many brands of cars and now it is available to any application.
The New Moton 4-way damper features 15 positions of high speed bump, 6 positions low speed bump, 15 positions high speed rebound and 10 positions low speed rebound. Both rebound adjusters are located on top of the piston rod and can be adjusted separately. Between the 2 rebound adjusters we mounted a small high quality bearing to make sure they adjust in dependably from each other and each adjuster features a clicking mechanism. Both bump adjusters are locates on top of the reservoir.
This unique new design features a blow off valve system in both bump and rebound. The reservoir is connected to the damper by a high pressure hose and is equipped with swivel banjo’s for easy installation of the canisters. Quick disconnects between the reservoir and damper are optional. All dampers come including spring hardware and mounting bushings.
The New 4-way damper can be produced as a McPherson strut in either aluminum or steel or as a Coil-over damper. It can be custom built to any application and to almost any required measurement.
Features
Separate Low- and High speed rebound control
Separate Low- and High speed bump control
Double piston design
Unique blow off valve system in both bump and rebound
Large piston rod diameter for more fluid displacement (low speed damping control)
Adjustable gas pressure for added lifting force
Swivel banjo hoses for easy install
Large main piston for quick response
No preloaded valve stacks needed to create low speed damping
Easy to use and work with
Proven reliability
Benefits
Improved platform stability
Improved traction, higher grip level
Improved curb stone and bumpy track control
Improved tire wear over race distance
Here's their new website for 2005
www.Motonsuspension.com
Old 12-11-2004 | 02:55 AM
KompressorKev's Avatar
KompressorKev is infamous around these parts
just butter...
Pharris409
11-01-2015 06:57 AM
Texas1
09-20-2015 09:12 AM
davetherave
Bentley
09-16-2015 06:30 AM
andbos
09-07-2015 07:13 PM
Quick Reply: 4 way adjustable Moton shocks!
