Recommended mods for track use?
Oh hell no... Touch the brakes and lose 10 seconds per lap in this little rollerskate!! Goal here is to get my two sons out racing endurance races in it, teaching them the art of racing, not the art of high HP addictions!
Mike
Mike
Can hardly wait for my brood to get old enouph to play with on the track. But I don't think anyone can avoid the high HP addiction once they decide racing is fun-it eventually get s us all! I certainly miss it.
I think you can get those on Suncoast for less (if they are priced per pair). I have meant to contact them...
http://www.e-partssales.com/miva/mer...de=986boxsters
The stock brakes are really that deficient? A set of PFC06's and good fluid/ducting aren't enough?
The suspension I can see, didn't know it took all the control arms, toe links etc to get it all up to snuff.
I was debating getting a GT3, but I want the car to be my daily driver and the Turbo is so much better in that respect as I live at altitude, so awd + FI+back seat = good.
Mike, thanks for the back up, too funny!!
Yea, if you were a beginner to intermediate student, the OEM brake caliper and rotor would be fine with some Motul, or other high end fluid and sufficient cooling ducts.
However, the upgrade to the GT3 6 piston caliper in the front and NON-drilled vented 350-355mm rotor will be an excellent upgrade of durability. The system won't give you tons of added braking ability. It will give you tons of consistent lap after lap braking at the same points for 20-30 minute sessions. The big issue is the car has so much more weight, and so much more ability to create more velocity that you'll cook the brakes at your driving level...
Franks new and enthusiastic! I'm sure we'll have him broke in nicely within the week, and then he'll be running the joint!
Mike
Mike
Heres a pic of the setup I run on the front, although I am considering moving to a floating rotor upfront this year:
And Why I love Pagid Yellows...
The fronts had 9 hard days use, and the rears had 16 days on them... Of course, they're cooked off thinner than I'd normally do, but I was at a Chin event trying to chase down a Redbull Racing 430Ferrari Challenge car with a pro driver in it... Me and the pads, we lost...
Mike
Mike
Is it easy to source the GT3 calipers used? Is there a "kit" out that includes the rotors, caliper carrier and calipers?
Sounds like this is a situation similar to my old turbo audi, even with larger stoptechs it would still bake the brakes...
It is easy to source the GT3 calipers. Suncoast, Vivid, GMG to name just a few. I needed a set in a hurry when I stripped a bleed screw prepping for a track event, and Dan at Vivid got them to me in two days.
I tend to disagree with Mike Kelly a little on the brake issue. I found that as I got better at driving the 996TT, I had less problems with the brakes. It's because I was using them less. I never had any brake fade issues with Pagid Yellows (RS 19) even on the 4-piston calipers. I did the upgrade to 6-piston only because I had to. I've been doing DE's for 17 years, instructing for 9, and I would say that I am not pussyfooting around the track.
Sounds like I just need to get the car out on the track with some ducts, fresh fluid and pads and see what it does.
That'll let me decide what I want to do suspension wise too. So how easy is it to change from street to track camber settings with the GT3 control arms? I'm used to just jacking up my car and slamming my camber plates over...
In the rear, I have adjustable dog bones instead of the GT3 control arm. (That's not to say that one is better than the other - just what I have.) Easier than the fronts - just count turns again. 1.5 turns on the front dogbone, 3 on the rear, and 0.5 turns on the adjustable toe link. I went to my favorite alignment shop the first time so that I could find out the adjustments needed between the two setups.
The exact number of turns etc. probably depends on the ride height.
Jon
Is the understeer a function of too little camber, or just mis matched spring/dampening rates?
That sounds like a PITA to swap toe/camber settings. How quickly with the car eat tires if left on track settings all the time?
Not at the same skill level as many of you ("B" group PCA & BMW) with a momentum car (R56 MCS) but would really like to tighten this car up a little without losing it's comfort on the street. Only plan on tracking it a couple of times a year.
Right after I bought the car, 01 996tt, I replaced all the brake components except the calipers thinking I'd be fine just swapping out pads to Pagids for track days.
Would it be best to just get this baby out there with the stock suspension and better pads (running Motul 600 fluid) and then figure out what suspension pieces are needed? Or should I just get some coilovers before taking her.
Hoping this car doesn't become addicting on the track. Told the BOSS when I bought it that she'd be a garage queen but she (the car) keeps on whispering to me every time I drive it that she wants to dance at the track.
Thoughts!
Cheers!
Thoughts!
Cheers!
Some people seem to be able to get that much negative camber without GT3 split control arms, some can't. I don't know why that is.
If you run with that much negative camber all the time, you'll wear out the insides of the tires pretty fast. Rear tires on these cars don't last very long as it is: 7000-14000 miles is typical.
Jon
