DIY Suspension Alignment Thread - Lets chat..
My suspension is stock except for a set of newly installed pss10s and a gt3 rear sway. I've been searching just about every forum possible for the last 7 days and posting the questions as an SOS, if you will.
-I'm at about a 25 3/4" ride height in front and I'm only getting about -1.2 camber in the front. I used the slotted holes in the front strut towers to adjust. Is this normal?
-How does I adjust camber in the rear? My ride height is about 26", with the left corner at -2.1 and the right at -1.8. I'm aware there is a cam bolt, but (embarrassingly) confused as to which bolt is the correct one.
-Finally, can anyone further explain how to adjust front/rear toe? Pics would be great, but a detailed explanation will do fine.
I have the longacre toe plates as well as the smartracing camber gauge. Any contribution would be greatly appreciated, as I'm at a real standstill. Thanks in advance!
Hope that helps.
Jon
The way that I would recommend set up the car to take a good track and street alignment is:
Front: GT3 control arms, adjustable caster bushing
Rear: Either of these two options:
Adjustable upper dog bones, adjustable toe link
OR
GT3 control arms, adjustable toe link
I have the first of those two options. I'm not sure, but I think some folks have both the GT3 arms and adjustable dog bones in the rear. There is also a locking plate (I don't have on yet) that a lot of people recommend. There was a recent thread on this.
Several of the suppliers have these parts: GMG, Vivid, TRG, ...
Jon
Anyone have success with these on stock turbo wheels? Appears at first glance it will be difficult to mount. Thanks.
http://www.racerpartswholesale.com/p...Gauges#reviews
Standard smartcamber gauge. If nothing else works, use a bungee cord wrapped around the spokes of the wheel and extending over the gauge.
If you really want to check the accuracy of your placement, turn the gauge upside down and compare camber measurements. Pos and neg camber should be equal.
04-28-2022 01:38 AM
