Set Up towards Oversteer??
the problem with tire sizes is that diff will see different sizes than expected,(if you change to 235/295)and so it will think wheels are spinning so feedback is needed...by doing so permanent it will overheated and finally burned...Mike,check your front diff if it operates properly...(lets hope it does)
I've swapped back and forth over the 3 years I've owned this car, almost from the beginning, keeping within the 3% variance without issues. Car is in the shop now getting the trans rebuilt and they checked the front diff... It's fine.
Mike
Mike
According to the Michelin site, the diameters of their tires are as follows:
225/40-18: 25.1"
235/40-18: 25.4"
295/30-18: 25.2"
315/30-18: 25.5"
So using the 235-295 pairing gives a difference of 0.2" instead of 0.1" in diameter. You could get that variance just from different amounts of wear front and rear.
Is that the spec, Mike, less than 3% difference in diameters? That would be almost 3/4" difference! That would allow you to use a 245/40-18 with either the 295 or 315 rear.
225/40-18: 25.1"
235/40-18: 25.4"
295/30-18: 25.2"
315/30-18: 25.5"
Guys if this is the case next time i will put 235 front...Has anyone else tried it?Mike i am quite happy you use them without any diff issues...Maybe i can eliminate my understeer problem now...
Second question to Mike is: Did you put the 235's on an 8" wheel? Michelin calls for an 8.5" wheel for the 235.
225/40-18: 25.1"
235/40-18: 25.4"
295/30-18: 25.2"
315/30-18: 25.5"
225/40-18: 25.1"
235/40-18: 25.4"
295/30-18: 25.2"
315/30-18: 25.5"
Sorry guys, was away from the computer all day...
Jon, I thought the variance in diameter quoted was 3%, but I may be wrong. I'll have to go back and check my notes. Bottom line is the 235 was within the tolerance/range for diameter differences. Remember, there has to be a minimal amount of difference front to rear or you'd have issues with heat related pressure expansion. Tires grow under pressure. How much? I don't know, but they do expand in all directions when at max pressure and max heat.
I used the stock OEM Turbo wheels without any issue. That's an 8inch wheel... and BTW, The guys at tirerack are with me on this one... There are ZERO issues to my knowledge with running a 295 rear and 235 upfront. Also, Michelin calls for a RIM WIDTH RANGE of 8-9.5 inches. I ran it on the 8inch rim with ZERO issues for the two years I ran this combo and will likely run it again this year.
Mike
Mike
... Also, Michelin calls for a RIM WIDTH RANGE of 8-9.5 inches. I ran it on the 8inch rim with ZERO issues for the two years I ran this combo and will likely run it again this year.
I have had my 996 TT for 9 months now and have gotten used to the driving dynamics of the car. I am trying to get my car closer to neutral as I am not pleased with how much it understeers.
Having had a NA 993 in the past, I got big kicks out of the oversteer and the ability to steer the car with the throttle and really wish this car had more of that capability.
Having said this, I know the extreme would be to disconnect front drive shaft and get a GT2 rear diff. My fear is this may be an extreme too far the other direction with massive oversteer, then I put the thing in a ditch.
Aroud this, I have a few questions for the forum: (this is for mostly general street use along with spirited driving on twisties and very occasional track use (like MAYBE one DE per year).
Has anyone taken incremental approaches to get the understeer out while keeping it AWD?
Has anyone gotten their TT to a nuetral dynamic with perhaps a 'lean' toward oversteer with suspension tweaks and closing the gap on the front/ rear tire widths?
Here is where I am at present: I have put H&R Coilovers on the car and it feels much better, but still understeers. I have ordered the rear H&R Sway hoping this helps to a large extent.
If this doesnt get me there, then I will get the front sway to soften up the front to dial out even more understeer. The last thought would be to close the ratio of the front/rear tire widths. Like 235 or 245 on fronts while leaving 295's on rear.
For those that have increased front tire sizes for this reason; Did you just put these on TT stock wheel dimensions or go to a GT2 wheel width, and which is preferred? (from an aestethics persepctive, my preference would be a larger wheel width) but not sure if it matters all that much.
I understand it may never be possible to get the car to oversteer like a RWD car, but am looking for solutions that will at least allow me to step the rear out without putting the car at the very 'edge' to do it. Based on everything I have read on this in the forum, these appear to be the steps to take to get the car where desired, and am guessing its allot of trial and error with each iteration of changes to see if the car handles as desired with each change...but am just looking for feedback on what others have tried and experienced making these types of mods.
Thanks in advance for the feedback.
~Ken
~Ken
You can go with the trial and error approach, but you're better off finding a good shop with lots of experience with these cars and let them set it up right the first time.
I have no idea what pp have said so far.
But you DO NOT need anything fancy to reduce understeer.
All you need is an alingment.
Get some toe out the front and toe in at the rear
get a good negative alingment. I'll find my spec sheet
and BAM, i can throttle steer/drift the car like a gokart,
with very little understeer...... toe in at the rear and out at the front
is not for the faint heart.
Toe out at front?for sritited road use...interesting...i use +1,0mm total toe in front and +3,0mm total toe in rear and the rear end is glued on the road...Also on Tuesday I set pss10 one point harder in front...and the car was very different...Understeer almost gone...Front end seems way much stiffer than before and turn in is better now...I like it better that way...
Toe out in front is good for the track but I personally don't like the front end wandering on the street. A little toe in at the front is more neutral. Maybe there is more understeer, but with all the other suspension upgrades I have, I don't notice it. To each his own.
I see...so toe out in front causes car to hang left and right at straight line...Every time i have this feeling i check allignment and always find front toe out...Weird...i reset it to +1,0mm toe in and after 3000-4000km again i have the same feeling...
There is nothing wrong with that, it's under 1% (.007) in variation and will not cause any problems, ever. All tires can't be grouped together as heights at different profiles will be different from one tire to the next. You have to research the indvidual tires, but the numbers given before was a good guideline for where to start.
I think the rear sway will reduce the understeer plenty enough for the street. I've never had turn-in oversteer in my car unless my steering inputs were not smooth and even then it was easily correctable.
