Tire Pressure
Along the tire pressure lines but a little different as I am planning a longer trip on Blizzaks across Nebraska to Colorado late January and expect/hope for clear interstate and snow in the mountains.
What are people running for their Blizzak/Winter tires as I have seen widely varying pressures.
I have experimented with low pressures (30/32 PSI) in heavier snow and the grip is very good but at speed the handling is definitely worse.
However, at the higher levels as recommended for highway driving (40/45) the traction in deep snow is definitely affected.
I throw this out for experience/thoughts/opinions as I sit with the thermometer at 0F. However, I am still driving at 0F In a p-car
I think for winter I have Blizzaks at 40 all around. They turn the turbo into an unstoppable snow eater. bAn absolute gas to drive up to about 6 inches of snow. Highly recommend.
Glad to see you still tooling around at 0. Your not going to Camp 4 are you?
Street use: Stock rec 36psi FR and 44psi Rear. If my tire is 19" Michelin, should I use same number? (I saw 80shilling Post said Mich. rec. 34F 36R, track or street?)
By running 20" wheels you are sacrificing a lot of performance with this car. 19s are about as large as you wanna go with this car.
i use 19s.
38psi front and 40 rear
#TeamAIM
#TeamAIM
04-28-2022 12:38 AM
RallyBird
10-07-2015 01:20 PM
horsepowerfarm
09-10-2015 06:09 PM
COBB Tuning
09-09-2015 09:13 PM
