Anyone out there road forced their wheels?
Old 01-13-2010, 10:13 AM
LovemyTT's Avatar
LovemyTT is infamous around these parts
I put new tires on my TT & had a little vibration in the steering wheel & went to a shop that does road forcing & took the vibration right out. $80 well spent.
Old 01-13-2010, 10:36 AM
adam699's Avatar
adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !
What exactly is Road Forcing?
Old 01-13-2010, 11:05 AM
RiA's Avatar
RiA
RiA is online now
RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !
Yep - the shop I use has the:
Hunter GSP 9700 Road Force Measurement Wheel Balancer
The Hunter GSP 9700 simulates road conditions with a "load roller" that applies 750 pounds to the tire while it's rotating on the machine, and incorporates Wheel Force Variation to detect out-of-round tires and stiff spots on tires that cause vibration. Unlike machines found in most shops, that only address up-and-down balance, the GSP 9700 addresses
up-and-down AND side-to-side balance.
Old 01-13-2010, 11:08 AM
jpflip's Avatar
Never heard of road forcing . Can you explain?
Old 01-13-2010, 11:13 AM
ETW 360's Avatar
ETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant future
Road Force balancing (not actually done on the road) is basically just high speed balancing. I always get it and never have any vibrations.
Old 01-13-2010, 11:34 AM
LovemyTT's Avatar
Just like the previous posts, it matches the wheel/tire together perfectly.
Old 01-13-2010, 12:13 PM
Tom@Champion's Avatar
Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !
RoadForce balancing is a must! We use it on every single wheel/tire we mount and balance.
The RoadForce maching uses a large roller that applies pressure to the tire, to simulate driving with weight. It's also able to detect imperfections in the tire if they exist. It's a must when balancing!
Old 01-13-2010, 01:05 PM
LovemyTT's Avatar
I put 4 new tires & had an alignment on my car & it drove like crap & was thinking something worse was wrong maybe with the suspension. Then during the roadforce it showed that the right front tire had a high spot & once we changed that one tire out & roadforced it everything is perfect now.
Old 01-13-2010, 01:19 PM
damon@tirerack's Avatar
Moderator
Hunter's website has a great explanation of it here.
The best part of the machines is that if your tire is out of round, especially laterally, it has the ability to tell you. It's all we use here as well, and it's usually the only machine that will tell you if a difficult tire can be balanced or not.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Old 01-13-2010, 05:34 PM
jpflip's Avatar
We learn every day. Thanks all for these valuable informations....
Old 01-13-2010, 06:14 PM
adam699's Avatar
Any way to find shops that offer that service?
Old 01-13-2010, 06:28 PM
earl3's Avatar
earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !
http://www.gsp9700.com/pub/search/findgsp9700.cfm
note that these are shops that have the hardware to do it -make sure you specifically request it.
Old 01-13-2010, 07:14 PM
wross996TT's Avatar
I have only had the hunter balance with road force ....is there anything else?
Old 01-13-2010, 08:37 PM
ruffinit's Avatar
ruffinit is a splendid one to beholdruffinit is a splendid one to beholdruffinit is a splendid one to beholdruffinit is a splendid one to beholdruffinit is a splendid one to beholdruffinit is a splendid one to beholdruffinit is a splendid one to beholdruffinit is a splendid one to behold
I ONLY road force..
Old 01-13-2010, 08:50 PM
ard's Avatar
ard
ard is offline
Same here, road force.
I actually bought new wheels and tires from Tirerack. If the road force shows an 'imbalance' they actually do a 'force match' in which they try and rotate the tire around the wheel so that the variation in the wheel and tire 'cancel'. I got three wheels to close to perfect, and one would not match even after 3 tries. Tirerack exchanged the one tire, no fees, no shipping, AND refunded me the cost of the bad roadforce.
Quick Reply: Anyone out there road forced their wheels?
