DIY Brake pad disc change remove and replace
Old 11-03-2015 | 06:39 PM
jpflip's Avatar
I use it on the BMW and Mercedes, on the hardware as anti seize and guide pin to help pad movement. Some people use also an anti squealing paste to prevent high pitch noise from the pads.... I always put little bit of anti seize or anti corrosion grease on all the bolts and fasteners I am installing on all type of cars.....
  #62
Old 11-03-2015 | 06:41 PM
jpflip's Avatar
Originally Posted by no1joey
Is this not done by everyone?
I don't on the Porsche but I do on the bimmer and MB.....Porsche want the vibration dampers to stick on the pads.....
  #63
Old 11-03-2015 | 07:12 PM
no1joey's Avatar
no1joey is a name known to allno1joey is a name known to allno1joey is a name known to allno1joey is a name known to allno1joey is a name known to allno1joey is a name known to all
This stuff looks like it might work http://www.bendix.com.au/content/hig...rake-lubricant
It does say it can be applied to shims/vibration dampers. Im not sure though if thats the contact points or in-between the vibration dampers and back of the pads..?
  #64
Old 01-29-2016 | 03:41 AM
Jason996Boston's Avatar
Jason996Boston is infamous around these parts
Here is a nice video on how to do the exact same thing:
Some people like video's with commentary!
  #65
Old 06-16-2016 | 12:43 PM
turboslut's Avatar
turboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant future
Do the caliper bolts need to be replaced or can they be reused? To be clear...the bolts that hold the actual caliper to the spindle.
  #66
Old 06-16-2016 | 01:09 PM
Ck986's Avatar
Ck986 is infamous around these parts
I believe they should be replaced per Porsches instructions, but don't believe anyone does including the dealers service dept.
  #67
Old 06-16-2016 | 03:18 PM
turboslut's Avatar
Yeah....confirmed, they need to be replaced.
COBB Tuning
01-29-2022 09:42 AM
2lflat4
11-18-2019 05:05 PM
gulf gt
08-27-2015 10:27 AM
Lucid Moment
08-20-2015 02:22 PM
ECS Tuning - BMW
08-19-2015 09:29 AM
Quick Reply: DIY Brake pad disc change remove and replace
