car dying and sputtering - problem seems fuel related?
Old 01-22-2010 | 12:16 AM
flash68's Avatar
flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !
Originally Posted by John@SpeedTech
From my experience, if the MAF is bad the car will run terrible with it connected. If you then disconnect it, you will have a couple of lights and codes, but the car will run near perfectly. If it still does not run well with the MAF disconnected, I think you have another problem. That said, I am not an expert at this, but I have had a couple of MAF's go...and this principal worked for me.
Well and that CEL code I hadn't had in a year surely points to MAF. I really hope it's a bad MAF tmrw.
  #32
Old 01-23-2010 | 05:13 PM
flash68's Avatar
Angry
Okay this is really pissing me off...
New MAF didn't fix it. Unplugging battery and reconnecting didn't help.
The symptoms are somewhat erratic - sometimes driving okay for a block or 2, and then bucking and sputtering and idle surging. And toward the end of the day it would not even hold idle it just kept dying upon start up.
Gonna mess with it again later today. Gonna do a real pressure test with air compressor (should have done this earlier, I know).
If that doesn't find the problem, maybe thinking a cat is clogged? Gonna try to peak inside there if we can see.
This is such a pain in my *** because this is my daily driver and it's been down for a week.
  #33
Old 01-23-2010 | 06:16 PM
check for codes... run durametric if you have it... email Tony...
you sure you have al the coil plugs on the coils...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
  #34
Old 01-23-2010 | 07:06 PM
drjoe's Avatar
drjoe is a jewel in the roughdrjoe is a jewel in the roughdrjoe is a jewel in the roughdrjoe is a jewel in the rough
you have the 72lb injectors? when was the last itme you change plugs--which ones?
  #35
Old 01-23-2010 | 07:39 PM
ttboost's Avatar
Definitley check plugs and coils. Make sure they are all plugged in. I still have my stock MAF, (knock on wood sound here)
  #36
Old 01-23-2010 | 07:44 PM
John@SpeedTech's Avatar
How is your fuel pressure when this is happening? Clogged FPR is a possibility.
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
  #37
Old 01-23-2010 | 07:45 PM
ttboost's Avatar
or filter? they checked fuel pressure and it was low, so they changed the pump and still no good...
  #38
Old 01-23-2010 | 09:10 PM
flash68's Avatar
I talked to Tony yesterday and he was insistent on a system pressure test, not just visual. Should have done this first. The inlet pipe on the passenger turbo was disconnected. DOH.
Hey, at least I have the updated fuel pump now. (This is me trying to have a good attitude about this).
Lesson learned: Always do free/cheap/easy tests first - MAF, pressure test, battery reset, etc. Replace expensive and labor intensive parts later.
My mechanic did say it is strange that these alpha turbos dont have a lip where the inlet pipe connects like the factory and other turbos do which help it stay on. Wonder why. ?
Thanks for all the help guys.
  #39
Old 01-23-2010 | 09:15 PM
ttboost's Avatar
Inlet pipe into the compessor or the pipe from the compressor to the IC?Are you using hose clamps or T-bolt clamps?
  #40
Old 01-23-2010 | 09:28 PM
jjbravo's Avatar
jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !
Good you've got the new pump.
It'll keep this from happening to you like it did to me in the middle of nowhere...
  #41
Old 01-23-2010 | 09:59 PM
flash68's Avatar
inlet pipe into compressor. and I believe they used the factory clamps but I am not positive. should those be the upgraded t-bolts?
Yes, I agree. Even if it wasn't needed now, it will be good to know that has been updated.
  #42
Old 01-24-2010 | 12:14 AM
aroonkl's Avatar
aroonkl is a jewel in the rougharoonkl is a jewel in the rougharoonkl is a jewel in the rougharoonkl is a jewel in the rough
-Glad you sorted it out Dave.
-jjbravo: I really like your exhaust tip. Single big cannon shot. Cool.
  #43
Old 01-24-2010 | 01:17 AM
BLKMGK's Avatar
If you had unplugged the MAF it would have run correctly wouldn't it? Just curious should I have to deal with this at some point
  #44
Old 01-24-2010 | 01:23 AM
Not with a turbo hose off. If the MAF fails, you can disconnect it and the car will run well. But not with other problems.
2022 Cayenne White
  #45
Old 01-24-2010 | 01:30 AM
flash68's Avatar
Thanks Aroon. I was thinking about those big tips too. They look good!
Makes sense. Funny thing is I was damn close to getting a clutch kit and inlet piping kit (waiting for AMS to release their new one) to get installed at the same time as my GT2 slave. Oh well. Another lesson learned and insight gained.
Perkman87
11-19-2015 06:31 PM
PorscheEnthusiast
11-13-2015 03:23 PM
gulf gt
08-27-2015 11:27 AM
Rumrunner
Charity Notices/Events
08-20-2015 12:07 PM
saline
08-19-2015 01:25 PM
