Guys running 305's with y-pipe intakes: input needed ...
Old 01-20-2010, 01:57 PM
bmoores's Avatar
bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !
Having some problems with rubbing even with spacers on. Any suggestions. I'm at GT2 ride height. Running 305/35/18 555R's.
Old 01-20-2010, 02:00 PM
PAULIEWALNUTS's Avatar
PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !
Ben are you rubbing on the fender liner or the fender lip?
Old 01-20-2010, 02:01 PM
unvmy996's Avatar
Ben, im running 315's with spacers in the rear ,i had to slighty flatten a part out a bit to make sure there is no rubbing at all , at anytime and im good to go now.
Old 01-20-2010, 02:03 PM
Just re-read the initial statement,disregard my previous question.
Old 01-20-2010, 02:05 PM
DNugget991GT3's Avatar
i dont think theres a way around that
im running 315 30 michelin cups and i rub occasionally... and my fenders are rolled aswell
Old 01-20-2010, 02:07 PM
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
I've been married nearly 15 years, I would welcome a little rubbing.
BTW, when did you get DR's?
Old 01-20-2010, 02:09 PM
bmoores's Avatar
They came in on monday Todd.
I know the rubbing will be unavoidable on occasion but right now we have solid contact.
Old 01-20-2010, 02:22 PM
Dr_jitsu's Avatar
As in your situation, Todd, my wife has become really skilled at avoiding all rubbing. A pity since she has finally gotten her pre-baby body back.
I hope I have the same "luck" with my new fender-wall intake/tire set up
Old 01-20-2010, 02:28 PM
tell me more about this fender set up... im curious if theres a way to put 325 30 19's on my car
Old 01-20-2010, 02:48 PM
ttboost's Avatar
Maybe she has just avoided rubbing you?
Old 01-20-2010, 02:58 PM
UrbanHotrod's Avatar
UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !
I second that!
Ben I have the 305" with the y pipe and i had a little problem until i massaged the fenders a touch and when running 35 psi it was fine as soon as i put it to 20 it touched the tubes, you may have to lightly tap the pipes where you see it marking with a soft blow hammer.
Off topic - Sean will take that as a soft blow Hummer
Old 01-20-2010, 03:43 PM
Divexxtreme's Avatar
I had the same setup as you; 305/35/18 555Rs, Proto y-pipes, lowered to GT2 specs. I rolled my fenders in my garage and installed 21mm RUF spacers out back and 7mm spacers up front. Problem solved.
Old 01-20-2010, 09:11 PM
robmd99's Avatar
robmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond repute
I have 315 DR radials on the back of mine. Just take your car to Motowerks and have Akram fix it for you.
Robert
Old 01-20-2010, 10:47 PM
tone01's Avatar
tone01 is infamous around these parts
pipe
if your talking about the intake pipe rubbing the tire i used metal strap used by plumbers {metal strip with hole wraped it around then screwed it to the frame rail with self tapping screws or pre drill with 1/8 drill bit pulls it in closer and makes it really soild
Old 01-21-2010, 12:09 AM
Here is the solution...
I use the stock thread and bolt to hold it down by making a bracket... it has fitted on a few big wheel set ups...
It is hard to make everyone happy... considering the different wheel/tire/suspension set ups... and it looks easier then what it takes to make it...
mark
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Quick Reply: Guys running 305's with y-pipe intakes: input needed ...
