2WD conversion, need outer front stub axles asap!! Can they be bought somewhere?
Old 01-31-2010, 01:09 PM
MrWhite's Avatar
MrWhite has a reputation beyond reputeMrWhite has a reputation beyond reputeMrWhite has a reputation beyond reputeMrWhite has a reputation beyond reputeMrWhite has a reputation beyond reputeMrWhite has a reputation beyond reputeMrWhite has a reputation beyond reputeMrWhite has a reputation beyond reputeMrWhite has a reputation beyond reputeMrWhite has a reputation beyond reputeMrWhite has a reputation beyond repute
Hi, does anybody here know if the front outer stub axles/tension bolts can be bought somewhere (in order to make 996TT 2WD conversion by removing front half-shafts + front diff + driveshaft)?
I'm not into the idea of killing my own front half-shafts, so I'd like to just remove them and plug in new outer stubs and make a nice neat swap (I haven't had any problems removing the stub nut, just needed the right mega tool ).
Thx!!
Old 01-31-2010, 04:32 PM
ttboost's Avatar
You likely won't find the stub axles for the turbo. Most here just take the axles apart. You won't ruin them and it doesn't take much time. maybe an hour for both sides. Just pull the boot back, clean the grease, squeeze the "hard to see" clip, pull stub axle off (might have to tap it off lightly with a hammer), remove small cage and marble sized ball bearings, clean all the grease out and you're done.
Old 01-31-2010, 08:42 PM
Turbo Fanatic's Avatar
I don't think you can put them back together after splitting them... at least that's what I've read.
Old 02-01-2010, 04:28 AM
ttboost's Avatar
They can absolutely be put back together. It's only a clip thats keeps them together. It's VERY hard to see and most people just hammer the stub axle off over this clip I guess?
Old 02-01-2010, 09:42 AM
onelove's Avatar
onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !
You can put them back together no problem when taken apart properly. I had found a part number for what appeared to be the stubs by themselves, however when it came install time they were not correct so we ended up splitting the axles anyway.
Old 02-01-2010, 10:37 AM
Cool. It's great to see a rumor dispelled.
Old 02-01-2010, 10:47 AM
2muchtime's Avatar
2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute
Exhaust
Sorry for getting off thread.....
Ari - how do you like your Remus exhaust? loud? any drone ?
Old 02-01-2010, 01:02 PM
MrWhite's Avatar
Thx for updates! I guess clean and split em up will be the medicine for this one.
04-28-2022 12:38 AM
Enemy
11-10-2015 08:01 AM
03EvoIII
09-21-2015 04:38 PM
Quick Reply: 2WD conversion, need outer front stub axles asap!! Can they be bought somewhere?
