Who changed to a fixed rear wing?
Old 02-02-2010 | 10:27 AM
landjet's Avatar
I would like to buy both of the screw-in metal connector fittings from your stock wing. They are the fittings that connect to the hydraulic rams. PM me.
Old 02-02-2010 | 10:44 AM
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
Still can't get those suckers out Larry?
Old 02-02-2010 | 10:49 AM
landjet's Avatar
I need an extra set.
Old 02-02-2010 | 08:54 PM
landjet's Avatar
Come on guys, I know a bunch of you have changed your wings.
Old 02-03-2010 | 10:09 AM
landjet's Avatar
Bump.
Old 02-03-2010 | 11:39 AM
Mad Ness's Avatar
Mad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant future
my wing hydros are busted and wing's in stuck up position. Want to keep it this way, as a spare or for when sell the car.
Not familiar with the part you need.
If removed, will the OEM stuck-up-position wing still be useable and visually the same?
If so don't mind helping out.
Old 02-03-2010 | 01:17 PM
LamboTT's Avatar
LamboTT has a spectacular aura aboutLamboTT has a spectacular aura about
Landjet, if your talking about an aftermarket carbon wing that you need spacers for, I got the same one. I got some spacers from ACE hardware last week and it sits just above the rear wing now. Works fine up and down. I think that it has effected the balance of the car somehow with too much downforce or more lift...At high speeds, it seems to squat more in the rear now over bumps. Let me know your thoughts on this.
Old 02-03-2010 | 01:21 PM
PrecisionPorsch's Avatar
PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !
This is the part that he's referring to
Edwin
Old 02-03-2010 | 02:10 PM
landjet's Avatar
Yes, that is a picture of the fitting that is screwed into the bottom of the wing. Thanks Edwin.
Mad Ness, thanks but if you are using the wing you won't want to take these out.
Anyone who has removed their stock wing and replaced it with a stationary rear wing and deck lid should no longer need these fittings. I am happy to pay for them.
Old 02-03-2010 | 02:19 PM
landjet's Avatar
What kind of spacers did you use?
Do you find that the squatting causes any handling problems? I wanted to use this wing at the track but at 150mph, I can't afford any handling problems.
Old 02-03-2010 | 04:47 PM
LamboTT's Avatar
I'm not sure to be honest..It might just be more downforce I'm no aero engineer. I'll make a high speed run tonight and post back my thoughts.
Old 02-03-2010 | 06:57 PM
Turbo Fanatic's Avatar
More downforce should only help IMO
Old 02-03-2010 | 08:41 PM
landjet's Avatar
As long as it is balanced with the front, I would agree with you.
Old 02-03-2010 | 09:08 PM
LamboTT's Avatar
Well I took it into triple digits somewhere and it seemed stable with no weird difference. It might just be more rear downforce as I don't think it can have any more lift after looking at it. I believe its a carbon copy of the techart bolt on wing for the 996tt. Same one John @speedtech had on his site before it was discontinued. How do you get more downforce or the front while keep the stock Turbo lip and bumper...any tricks? Its already about GT2 height, go lower in the front?
Old 02-03-2010 | 10:06 PM
CAA's Avatar
CAA
CAA is a name known to allCAA is a name known to allCAA is a name known to allCAA is a name known to allCAA is a name known to allCAA is a name known to all
Here's a shot.
Quick Reply: Who changed to a fixed rear wing?
