DIY Battery replacement
Sean if my neck wasn't in the process of going to hell again I'd come over and do it. It's really simple, because I've done it before on mine. I think it took 10min or less. Loosen the terminals, then unbolt the battery tray bolt and lift up. There maybe a tube connected to the battery, just disconnect it and prepare to hook it back up to the other one. When you put the other one in, make sure it goes back in the same place and put the tray bolt back in and hook up the terminals and you are good to go.
When I did mine, my battery completely dead and wouldn't hold a charge. So I didn't even bother with it. You can hook up a battery tender possibly to it and you will not have to worry about having the car relearn everything. But like I said it didn't do anything to mine that I noticed.
What brand of battery did you get? If it is a Optima battery you need a special mount.
Going to get an Interstate, although the top of the line batteries at Walmart are supposedly just as good.
I just wonder if it will fit. Going to pick up the Walmart battery tonight, if it doesn't fit I will return it and go to my mechanic tomorrow. $80 for the install is cheap, but he charges wholesale ($120) for the battery.
Yeah, let us know what you get and how the fitment and install goes.
I've got an 03' and it's got the original battery and it's starting to go and will need replacing soon.
I've also heard that the interstate model is the best.
Looks like model Interstate MTP-91 is what you'll need. Also, about 10 lbs lighter than OEM battery.
Where are you buying from?
Interstate will fit just fine. I have one in my car (model #mpt91). Piece of cake to install 10 min or less. Interstates have vent tube that you reconnect as well (at least this one does). No tender needed but you will have to reprogram your radio / code if you don't keep some level of charge. I have never worried about the reprogramming process and just swapped them out. $80 to change sure seems high since no mechanic on earth should charge more then 1/2 hr to install.
HTML Code:
Check the nut size of the battery terminal bolts, if you don't have the correct size wrench, buy one.
Don't hammer on the battery terminals to get them back on your new battery. Clean the terminals, outside of posts, inside of cables, before reattaching. They should be the bright metal color of newly exposed lead.
Don't wear good clothes and don't touch either battery to the inside of your trunk or your clothes.
You might want to attach you battery tender or charger to the terminals, and keep them attached during the R&R.
Any tool that you have to buy, you get to use again. No money is ever wasted on purchasing tools.
The next time you do it will take 10 minutes.
Yes, MTP 91 is the one that fits. I called around and everyone's prices were at least $20 more than my mechanic.
I am tempted to just go buy the battery from him and then drop it in myself in the parking lot of his shop
It'll take all of 10 minutes.
Yes, but their techs wear metal (keys etc.) and lean against the car.
I would never let a Walmart tech work on my Porsche.
The Jeep...maybe.
There are too many other choices for the same service where I wouldn't worry about the quality of service or the keys on the paint.
