Is it safe to use "75w /140 gear oil" vs the standard "75w /90" weight in the diff?
I found a specific gear oil I want to use in my diff.. Its weighted 75w/140.. is this safe to use even though the standard weight is 75w/90 in the differentials?
The builder of my trans recommend that I use http://www.le-inc.com/products.jsp?productID=253
That product you recommend Peter is another I'll have to check out. But unless they have the aftermarket components you and I have, I'd recommend these guys stick with the OEM fill... There are a couple of guys who've switched from the factory fill on stock boxes and found gear engagement to become much more harsh.
Mike
Mike
I understand peoples concerns about the type of fluid, but my question is the diff compatible with a 75w-140weight vs 75w-90 stock...
I assume no.
I assume no.
I would speak to Erik, Matt or Brian at the following Numbers and get advice.
Erik Johnson
GBox Performance Transaxles
(303) 440-8899 work
(303) 895-4828 cell
Matt Monson
Guard Transmission LLC
Tel: (303) 530-1094
Brian Copans
BMC&G
3315 Ladd Ridge Rd.
phone: 740.593.8936
fax: 740.593.8933
Erik Johnson
(303) 440-8899 work
(303) 895-4828 cell
Matt Monson
Tel: (303) 530-1094
Brian Copans
BMC&G
3315 Ladd Ridge Rd.
phone: 740.593.8936
fax: 740.593.8933
Thank you for taking the time to give me those references.
Im going to switch the the Willall 75/140 Diff fluid. It was specially formulated for the track and is used religiously in the GTR cars with extensive comparisons and fantastic results..
Cheers
Cheers
ModBargains
997 Turbo Vendor Classifieds
10-13-2015 03:55 PM
ModBargains
997 Vendor Classifieds
10-13-2015 03:53 PM
ModBargains
996 Turbo Vendor Classifieds
10-13-2015 03:52 PM
ModBargains
10-13-2015 03:52 PM
