Would you run Magnesium wheels on the street?
Old 02-15-2010, 12:52 PM
kerryt1's Avatar
kerryt1 has much to be proud ofkerryt1 has much to be proud ofkerryt1 has much to be proud ofkerryt1 has much to be proud ofkerryt1 has much to be proud ofkerryt1 has much to be proud ofkerryt1 has much to be proud ofkerryt1 has much to be proud of
Originally Posted by damon@tirerack
I'd like to see proof Chevy used true magnesium for a production wheel on a car made in that kind of quantity. I don't know (doubt) if this is accurate. I seriously doubt Chevy would spring for the tooling it took to make them, but that's opinion. Remember, people have a habit of referring to cast alloy wheels as "mags", but that does not mean they are constructed of magnesium. The only true production magnesium wheel I know of was for the Carrera GT, at 8k a pop. There may be more, but if so they would be for very expensive, very exclusive cars. The stuff is just too expensive, and too hard and dangerous to work with.
As I mentioned, I'm not sure of the alloy. I do know it's more than slang for an aluminum alloy wheel. Even though the Corvette is a bargain-basement sports car, I find it unlikely that GM would market a slang term from 20+ years ago.
FWIW, GM has been outsourcing some wheel manufacturing on the Corvette for some time. The 2001 Z06 wheels were forged by Alcoa, and 2002-2004 Z06 are spun cast by Speedline. I do not know of the manufacturer of the magnesium wheels, but I would bet they were made by somebody else.
Old 02-15-2010, 01:53 PM
damon@tirerack's Avatar
Moderator
Well, I was WRONG on this.....
I did a bit of digging and they did if fact have an optional magnesium wheel. I asked a guy I work with who is very familiar with the cars and he did confirm if it was in fact ALL magnesium, not just terminology. Interesting fact: They had to have a hard plastic insert between it and the hub to keep it from corroding itself to the car.
Made by Speedline, here it is.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Old 02-15-2010, 02:16 PM
Fabryce@GMGRacing's Avatar
Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !
I've run Champion mags on our GT2 for years with no issue.. Both on street and on track.
BBS 1 piece Mags have had issue with cracking at times due to the thin barrel design.
http://www.gmgracing.com/images/gmggt24big.jpg
Old 02-15-2010, 02:54 PM
Moderator
Originally Posted by PAULUNM
Thanks Damon- so would you not reccomend a set of Champion or other mag wheel? I would have to assume that they are using an alloy that would make flammablity less of an issue...
Magnesium is favored by race teams because it is 33% lighter than aluminum (raw). Magnesium is a highly flammable metal, but while it is easy to ignite when powdered or shaved into thin strips, it is difficult to ignite in mass or bulk. A ribbon of it ignites at about 1200 degrees, and a solid wheel would need to be over 3000 degrees to burn. Remember, aluminum burns, too. It just has to be hotter to do it.
damon@tirerack.com
Or use this link:
COBB Tuning
01-29-2022 09:42 AM
The_Ruski_Driver
10-25-2015 08:40 PM
Bader996
08-27-2015 10:01 AM
pwdrhound
08-20-2015 05:54 AM
Quick Reply: Would you run Magnesium wheels on the street?
