Interesting 2nd gear pop out avoidance mod-
Thread going on in the 996 forum...
Tempting. Thoughts? I know these guys know what they are doing...
https://www.6speedonline.com/forums/...ml#post2728616
Gbox
These guys have a proprietary solution for the 2nd gear pop out. If anyone is going to develop "cheap insurance," you have to think these are the guys to do it.
http://www.gboxweb.com/996shimtip.html
This is exactly what was done by my indy when my trans was out of the car. I believe that any knowledgable indy will know about this... My guy had a bag full of those shims and was able to show me on another transmission that was appart how they set them up, pretty much what is explained in the Gbox link. I'm pretty sure this is also what Douherty did to Jeff's (JCBMemphis) transmission...
Mike
Mike
Mike
Mike
Yep, I paid about that much for the part and about 100x that in the other stuff.
Guys, if this is simple...it is worth doing!!!
I contacted Erik, and Brian C..., and I had Dougherty call and talk to Erik and a few other guys. Only when he was satisfied that this was the real deal would he do it for me. No issues in over 10k miles. I consider this a mandatory fix that PCNA should offer to all owners. Just my 2c. Cheap insurance. I have it in my car and would not want a manual 996tt without it knowing what I know and having to have my car get a rebuild....granted, by a cup car shop. The tranny was better (and still is) than new.
jeff
So you guys are saying if your second gear hasn't popped yet and you want to avoid it, getting these parts will fix the defect before it happens?
Subscribed
Subscribed
Ichiban - I realize that your question is directed to other member here, but I think that it should be clear. If you do not have this problem already, and would like to take preventative measures to help avoid it from happening in the future, this is the part you need.
If you already have this issue, then you still need this part, otherwise when your gearbox is rebuilt, the problem will arise again.
I hope that make it just a bit more clear.
Thanks everyone, we appreciate the opportunity to help, as well as the business.
Erik Johnson
GBox Performance Transaxles
(303) 440-8899 work
(303) 895-4828 cell
Erik Johnson
(303) 440-8899 work
(303) 895-4828 cell
Erik Johnson
(303) 440-8899 work
(303) 895-4828 cell
Erik Johnson
(303) 440-8899 work
(303) 895-4828 cell
Thanks Erik!
Paulunm, not a problem. Both factors should be taken into account here, naturally the shims are important during a rebuild, as they are often not placed back into the same position that they were in during disassembly. The idea here is pretty simple the shims control the stack height and thus the engagement of the 2nd gear. This is due to the fact that the 1st and 2nd shift fork is not adjustable, as it has been in other gearboxes. Since this is a solid point the only way to adjust the engagement it through the shims, or through the locking device, which also controls the amount of movement allowed by the shift rod, and thus the fork.
The part that we are offering basically allows the shift rod to move slightly farther when you move your gear shift forward and back, thus giving you a better engagement of the operating sleeve to the dog ring itself.
I hope that made sense as the how each part plays a roll in this. Please let me know if I was not clear enough.
Warmest Regards,
Erik Johnson
(303) 440-8899 work
(303) 895-4828 cell
Warmest Regards,
Erik Johnson
(303) 440-8899 work
(303) 895-4828 cell
As I recall there are TWO reasons for 'second gear pop out':
One is the incorrect stack height leading to the 2nd gear to the 1/2 operating sleeve being incorrect...essentially a mfg defect
The other is missed shifts leading to 2nd gear dog ring wear and then loss of engagement retention.
Two questions:
Is this true?
Does this fix address both failure modes?
Thx
A
Two questions:
Is this true?
Thx
A
