Engine and trans coming out
#31
Weld the glued in coolant fasteners that are known to pop out. I cannot easily describe where they are but John and others have had issues with them and if the engine is out weld those suckers in!
#33
Not easy to find! Here's one of them -> https://www.6speedonline.com/forums/...lant-leak.html
There was also another where the user posted a pic of both the weld in fitting that had failed AND the CNC fitting his indy used when welding in a fix posted recently. I'm still looking for that one for you!
Edit: Another that mentions it but not the one I want -> https://www.6speedonline.com/forums/...highlight=weld
Also consider replacing the coolant overflow tank while the motor is out. They crack with age and are a ***** to do with the motor in apparently. The aftermarket intake pipes John mentioned earlier are also a very good idea IMO.
#34
#35
#36
We got yer back...
#38
No. Send john@speedtech or dgreen78 a PM and he can likely tell you.
04-28-2022 12:38 AM
carwash
09-29-2015 10:43 PM
turbotuner20v
09-11-2015 12:02 PM
