Who is still using a stock MAF at 550+whp?
#31
Wonder if thats maxed out? I remember a few years back when "550whp was the max on stock MAF." Hopefully Tony can chime in.
#32
But I thought I also recalled that for an early car, originally with a 124.00.....that there was enough dif that a reflash was needed (at least on a stock car) before replacing the 124.00 with 125.00 or 125.01.
I have a couple lines out on this.....someone will set me straight.
#33
Keep in mind that there are other maf "solutions" on the market at the moment...most dont read any more air flow then stock... they just use a sensor thats less prone to failure.
#34
Thats about the limit that the stock MAF can read. We will be releasing a maf solution shortly.
#35
And for those running OE MAF over 550 (and apparently OK).....what's the downside for them?
TIA
#36
The only "down side", (if you want to call it that) is that you "have" to use a stock airbox and some kind of "oil less" filter (stock paper). Tuners will have to chime in on power limitations.
#37
Yes, the best way to run the stock MAF is with a stock air box and filter. I change my filter every 1000/1500 miles and I can tell a difference when new.
#38
I'm just wondering if the blown MAF can affect the out put of the car power.
Here in KUWAIT the porsche dealer is selling the MAF for about 831 USD. So i cant change it every 2 or three weeks. BTW i'm using EVOMS intake sys but gonna change it now to stock.
#39
After blowing a couple MAFs myself with the EVOMS v-flow, I removed it and have had no problems since either. Probably a wise move on your part.
#41
What MAF do you go to if you want to run a AFE, KnN, or BMC type filter?
#42
Until someone comes up with a permanant solution, it seems only a blow through system can accomodate those filters. I think it has been proven that these filters don't provide a huge increase and the stock paper filter and airbox will support whp of up to and over 700whp.
#44
The K&N's and other "oil" filters are what people are saying fouls the MAF. And those filters with NO oil filter nothing. I dyno'd filters and no filter back to back...not worth the aggravation.
