Pbox result-comments/critiques
Old 02-22-2010 | 10:12 AM
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
It was also suggested that I post on this forum to get some feedback. Any critiques/suggestions would be appreciated. TIA.
https://www.6speedonline.com/forums/...critiques.html
Old 02-22-2010 | 11:04 AM
MBailey's Avatar
I agree with what others have said. Looks like you have a pretty powerful TT but you launched it slowly and granny shifted it. I suspect you have mid-500s whp there. If you are worried about abusing the drivetrain, you should try a 60-130 starting at 30mph in third gear. Make one quick shift to fourth, run her to the limiter and you are done. This will give a clearer view of your whp without variables of launch and multiple shifts.
Old 02-22-2010 | 11:14 AM
TTdude's Avatar
Thanks. I appreciate the advice.
Old 02-22-2010 | 12:21 PM
MBailey's Avatar
You are welcome!
Do you mind going over what mods are on the car and what boost you are running?
Old 02-22-2010 | 01:47 PM
TTdude's Avatar
You are welcome!
Proto ECU, ICs, VTGs
FVD 200 Cell exhaust
Sachs Stage II Clutch
OEM SSK
Boost is unknown. I don't have sport chrono and the dial pegs at 15 psi and won't read any higher. Can a scan tool read boost accurately or any other suggestions? Thanks.
Old 02-22-2010 | 03:53 PM
MBailey's Avatar
OEM SSK
I dont know what to tick to read boost in Durametric. I might just call Todd K and ask what he set it at...
You are producing in the neighborhood of 675-700 crank hp based on your plot. Is this about what you were told the kit would produce? That is a very healthy number for VTGs, imo.
I would love to see a 60-130!!
Old 02-22-2010 | 07:14 PM
MrWhite's Avatar
MrWhite has a reputation beyond reputeMrWhite has a reputation beyond reputeMrWhite has a reputation beyond reputeMrWhite has a reputation beyond reputeMrWhite has a reputation beyond reputeMrWhite has a reputation beyond reputeMrWhite has a reputation beyond reputeMrWhite has a reputation beyond reputeMrWhite has a reputation beyond reputeMrWhite has a reputation beyond reputeMrWhite has a reputation beyond repute
+1 on 60-130 and work on the shifts. Looks like a good load of power on the long-acc numbers in 3rd and 4th.
Old 02-22-2010 | 07:38 PM
TTdude's Avatar
I'll touch base with TK about the boost. I thought boost was determined by what hardware one has on the car? The 675-700 crank is what Todd said I should expect. I am very happy with him. Couldn't be more pleased. I'll see what I can do but 60-130 should be more suited for a novice like me.
The car feels like it has more to give. I need to tap into it. Hopefully with some data logging and recalibration via Todd K, I will get a few more ponies out of her.
Old 02-23-2010 | 07:54 AM
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
I'll touch base with TK about the boost. I thought boost was determined by what hardware one has on the car? The 675-700 crank is what Todd said I should expect. I am very happy with him. Couldn't be more pleased. I'll see what I can do but 60-130 should be more suited for a novice like me. .
I'm interested in your 60-130 as well. Good luck.
Old 02-23-2010 | 08:30 AM
ttboost's Avatar
I'll bet you are there busy body...
Old 02-23-2010 | 09:29 AM
jpflip's Avatar
Sorry about this question but, I saw the word Pbox, Vbox, often but would like to learn about it. Can you give me a link that will provide me with info on what it is for, how it work...
Old 02-23-2010 | 09:39 AM
MBailey's Avatar
Here you go!
http://www.vboxusa.com/performancedr...ormancebox.php
Old 02-23-2010 | 09:46 AM
jpflip's Avatar
Thanks for this quick answer!
Old 02-23-2010 | 10:25 AM
TTdude's Avatar
I must be missing something here
Old 02-23-2010 | 10:32 AM
Yea, Mr. TTboost is giving me a hard time because he's bored. His car is probably covered in that CT snow.
Quick Reply: Pbox result-comments/critiques
