Dropping my car off at TPC Racing next week..
#286
Zac,
Below are the only pics I have. A few of the motor being put back together and of my stock rods.
My stock pistons were perfect and re-used. Installed Pauter rods. The aftermarket LA Sleeve liners that I bought, Mike refused to put in the car because he said they were out of round by 4,000ths and the stock liners were flawless and of much better quality (he said the LA Sleeve liners looked like they should be installed in a Z06, not a GT2).
He replaced all the lifters with the newer, superceded ones from Porsche, one of the cam boxes that was damaged when the lifter failed, and one intake valave that got damaged a well. Other than a new gasket kit (the stock one was fine, but as you know you always have to use new gaskets during a motor build), that's all that was replaced.
On another note; I took it out for a nice long drive last night. Ran her at 1.4 BAR on 93 octane. It was a blast.
I'll say it again though, I absolutely love your GT2
#287
Scott, wasn't the whole reason for the "rebuild" that the OEM liners were deemed not strong enough, and were begining to show signs of fatigue? I know you mention the part's have been updated, but I'm not aware fo too many new motors being taken apart that have been exposed to your power level, so I don't know if they could be considered any stronger than the other parts. I suppose the guys at TPC know a lot more than me though, so I guess I am just seeking confirmation for the rest of us
Thus, my motor did need to rebuilt, but for a different reason than was initially thought (see pics below).
What Mike told me is this: these Turbo motors are unbelievably strong. They are full-on race motors with the absolute best parts and the tightest tolerances. My pistons were perfect. My liners were perfect. My rods were perfect. Even after seeing close to 1.8 BAR.
He 'tentatively' admits that the Pauter rods are an upgrade, even though my stock rods are still perfect. With the amount of boost and torque I'm running, the Pauter rods are a definite benefit (he also said he was surprised at how perfectly they fit).
He feels that if I had not had an issue with my lifters, my motor could have been run at 700+ rwhp for an indefinite period of time in it's 100% stock configuration.
He also feels that a lot of the aftermarket parts out there are not near the same quality as the OEM parts are, and he would never put those parts in a Porsche engine. For his race motors, all he uses is Mahle parts, and he really doesn't think anything else compares. Mahle is very expensive, but well worth it in his opinion. Remember, his expertise comes from building race car motors for a living. Not street cars. So his standards may be quite a bit higher than others.
Based on my personal experience, I'd recommend the following: As long as you have a great tune and run the fuel that that tune demands, these motors are good for well over 700rwhp for very long periods of time, assuming you don't have a freak issue with lifters. If you drive extra hard (especially from a dig), and/or you are making a crap-load of torque, Pauter rods are a definite upgrade and will only add to the strength of the motor. If you do go inside the engine, ensure you inspect the lifters for damage and ensure they're the newest part #'s available from Porsche. If not, purchase new ones and have them installed (they are only $1,500.00 for the set). On a stock motor, I'd also recommend keeping the redline under 7400 rpm. 7k rpm is even better.
Thanks for the props on the car.
Here are some pics of the damaged lifters:
#288
Interesting as always Scott--thanks for sharing. What were the unused liners-- maker? From where? You stayed at 3.6? Correct?
What did you do to solve lifter issue?
Can you repeat full list of all mods(internal and external) as they are now?
#289
Yes, I stayed 3.6. Actually, nothing in my motor build will give me any more airflow or power than stock. I only went with new rods and lifters. No headwork, stock cams, same displacement, etc..
The lifters we installed are OEM Porsche, but they have new part #s from the original ones. So, apparently Porsche realized the original ones had issues.
Primary mods are as follow:
Hybrid T04B turbos
Proto intake/MAF
Proto headers
Switzer exhaust
TPC ICs
Piggyback fuel pump
60lb injectors
Proto/TPC tune
#290
Right now I'm just enjoying the car and figuring out optimum octane and boost levels. After it cools down, I'll get 60-130 times, 1/4 mile times and dyno #'s.
We've been dealing with a heat index of 110 degrees recently. Not fun!
#291
Lucky you have those bad boy IC's.Got to love 5" coolers.
PorscheEnthusiast
11-13-2015 02:23 PM
