light weight pulley
Old 12-27-2012, 08:36 AM
RCH's Avatar
RCH
RCH is offline
RCH is just really niceRCH is just really niceRCH is just really niceRCH is just really niceRCH is just really nice
Yes good point does it make any difference for a Tiptronic vs a manual
  #32
Old 12-27-2012, 10:23 AM
MBailey's Avatar
I assume pulley that runs all the belts is the same on tip and manual, so yes it would help a tip car too...
  #33
Old 12-27-2012, 11:39 PM
timccloud's Avatar
timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !
I have a BBI PULLEY good upgrade if you like to heel and toe much easier to match revs. well worth the 200 bucks
  #34
Old 12-28-2012, 03:39 AM
RCH's Avatar
RCH
RCH is offline
Obviously not on a TIP though, it would be so nice is something made it rev more freely
  #35
Old 12-28-2012, 03:56 AM
timccloud's Avatar
Give it a go on a tip i doubt you would be sorry in my opinion the BBI pulley is the way to go easy to order online from Tarrett Engineering
  #36
Old 12-28-2012, 04:36 AM
VAGscum's Avatar
The cheapest option is to run the GT3RS/Cup pulley. It is lighter than the GT3 and the 996TT pulley and can be had online for ~$75 plus hardware. Here is what you need. If the Cup cars run it, it is proven.
996 102 017 95 Crank pulley
999 025 174 02 Washer
996 102 550 80 Bolt
  #37
Old 12-28-2012, 01:09 PM
johnspeed's Avatar
996 102 550 80 Bolt
Hi,Thanks for that..
  #38
Old 12-28-2012, 03:42 PM
RCH's Avatar
RCH
RCH is offline
Do I need a new belt as well ?
  #39
Old 12-28-2012, 07:16 PM
VAGscum's Avatar
Not necessarily, but not a bad time to replace it. It is most likely worn in to your stock pulley and the other pulleys may be off enough to induce some slipping. It is only $35 for a belt.
  #40
Old 12-29-2012, 02:16 AM
RCH's Avatar
RCH
RCH is offline
ok and the belt is the same part as the 996 TT ?
  #41
Old 12-29-2012, 08:37 AM
VAGscum's Avatar
Not sure exactly you mean? The GT3RS/Cup pulley is the same size, but is half the weight and made of aluminum instead of steel. So the belt will not change unless you use a substantially smaller diameter pulley.
  #42
Old 12-29-2012, 02:06 PM
RCH's Avatar
RCH
RCH is offline
I thought the pulley wheel is smaller, than the TT version ??
  #43
Old 12-29-2012, 05:47 PM
VAGscum's Avatar
Nope. Same diameter and belt.
  #44
Old 12-29-2012, 06:07 PM
johnspeed's Avatar
Hey you can even put lightening holes in it to make it lighter..lol..
  #45
Old 12-29-2012, 06:39 PM
mod mike's Avatar
mod mike has a spectacular aura aboutmod mike has a spectacular aura aboutmod mike has a spectacular aura about
has anyone seen the way a stock pulley fits? if you haven't have someone show you. it is prone to break on mod cars, and if it does, there's no way to fix it besides replacing the main shaft.. cheapest insurance i've seen... if my car was stock, i'd still change it!!!
Quick Reply: light weight pulley
