White turbo blades
Old 03-02-2010 | 06:29 PM
Janker's Avatar
Janker is just really niceJanker is just really niceJanker is just really niceJanker is just really nice
Originally Posted by ant_8u
Yes Indeed
EDIT - Jim, is that the new addition in your avatar?
Yeah baby... You don't miss much!
Old 03-02-2010 | 06:35 PM
ant_8u's Avatar
ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !
You picking it up tomorrow?
As you said, we should all meet up
Old 03-02-2010 | 06:47 PM
Mpsuk's Avatar
Mpsuk is infamous around these parts
Yes mine are white like that picture, any idea what that is?
And Yes, would love to meet up with you guys, its quite awkward for me sometimes cuz i work late and dont have many days off but we can def arrange something soon, adam
Old 03-02-2010 | 08:35 PM
Turbo Fanatic's Avatar
Have you run race gas recently? Race gas does that for sure. I notice it inside my exhaust pipes when running hard even on 91 octane.
I would be concerned as to why only 1 side is like that though.
Old 03-02-2010 | 08:56 PM
Mpsuk's Avatar
Hi, i dont use race gas but i do use 99 ron fuel always, nothing else, im not sure how that translates in us fuel rating but in uk we have 95 ron ( unleaded ) 97 ron ( super unleaded ) and at shell petrol stations 99 ron or v-power which is all i use. Both sides have evidence of this but much more on one
Old 03-02-2010 | 09:23 PM
ant_8u's Avatar
Our fuel ratings are around 4-5 points higher than the American equivelant
ie 99RON is approx 94-95AKI
Old 03-02-2010 | 09:25 PM
I'd say that explains the white stuff. Do you run the car pretty hard?
Old 03-02-2010 | 09:26 PM
Mpsuk's Avatar
Yeah, when the wife is not with me!
Old 03-03-2010 | 11:38 AM
RoadSpike's Avatar
RoadSpike is infamous around these parts
Well I can tell you what I've been told but i don't have real expertise in the subject of turbine coloration due to leanness.
Basically the simple answer is when the black carbon soot burns completely it turns white just like ashes do in a wood burning stove. When they car gets too lean the white powder tends to coat the exhaust housing.
The obvious next step is to look at your plugs. If the plugs look normal your tune is perfect.
Edit:
Picture of one running a little lean
Old 03-03-2010 | 02:39 PM
Mpsuk's Avatar
Is it possible that if actuaters arnt tight enough that would cause 0.9 bar instead of 1.1 and then to much fuel goes through, hits the hot turbo and causes this??? Is that a possibility? Does anyone know how to determine correct preload on actuaters??
Old 03-03-2010 | 06:01 PM
ant_8u's Avatar
I can't see how the actuators would cause the whitening
They 'may' be part of a boost problem if you do indeed have one, but won't effect the whitening of the turbine wheel
The turbine wheel is after the combustion chamber so the fuel mix is already burnt when it gets there - all the actuator will do is direct the path of flow
Old 03-03-2010 | 06:44 PM
RoadSpike's Avatar
Unlikely the high fuel content would just make less whiteness appear on the turbine blades. More grey to black soot would be on the turbine than not.
Likely your tune is perfect check your plugs if you are concerned. Since I don't have hands on experience with tuning porsche's I can only tell you if they are like any other car the lack of boost shouldn't be an issue. The maps are designed to handle any range of running conditions.
Old 03-03-2010 | 09:02 PM
Mpsuk's Avatar
Does anyone know the common symptoms of coilpack breakdown, i think that could be a fault, would that stop the car making full boost if spark wasnt strong enough? Thanks for all your advice, very helpful
Old 03-03-2010 | 11:54 PM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
Originally Posted by yllwturbo
so thats where i left my money!!!!!!!!!! been looking for it for a couple of days now. could u please sent it to me. pm me for my new address...lol
It's only $40 in ones.
Old 03-04-2010 | 09:18 AM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
yea musta been a bad strip club if he got outa there with ones in his pocket..
white is a sign of a A/F on the lean side, have you done any changes since your tune? or dataogged the wideband o2 sensors lately? call your tuner and ask them
04-28-2022 01:38 AM
Perkman87
11-19-2015 06:31 PM
Just Cruise
08-25-2015 11:45 AM
The Oss
08-24-2015 09:19 PM
