Misfire or surging above 4500 at WOT ????
Old 03-02-2010, 09:50 AM
8757william's Avatar
8757william is infamous around these parts
yes I tried cleaning the MAF yesterday, It didint eem to make a difference thought. I am going to try unpluging it and see what hapens.
Old 03-02-2010, 09:51 AM
ttboost's Avatar
Originally Posted by 8757william
I have had this same issue with over 3 tanks of fuel from different stations, so I havent put much thought into bad gas. I have never seen it overboost. I will go check the plugs, I cant remember what they were, just that it was a litter bigger than the recomondations I could find, I used the preset gap from bosch.
I think a plug gap of .028-.030 is a good place to start, if you are going to check them all anyway. MAF's on these cars do create more problems than can be imagined.
Old 03-02-2010, 09:53 AM
ttboost's Avatar
It's not a good idea to build boost without a MAF. How may miles on that MAF? Maybe just change it, if it doesn't help, you have a spare MAF.
Old 03-02-2010, 02:14 PM
DRIVN Ind.'s Avatar
DRIVN Ind. is infamous around these parts
Mine was doing the exact thing. I switched to a hitachi MAF and cleared it right up.
Old 03-02-2010, 03:13 PM
I think I found my problem..
When I tested it with the MAF unpluged, the abs/psm lights came on but it reved out in the higher gears without any hesitation or surging!
I did it atleast 4 times, hopefully I didint run it lean..
I was surprised to find it was the MAF, because I had no faults pointing to it and I never had the abs/psm lights come on before. It looked fine and I even tried cleaning it.
So I already ordered a new Bosch one off ebay $285 cdn shipped.
Thanks for all the help, I'll post back in a couple weeks after I get the part and try it.
Old 03-11-2010, 01:27 PM
Yes, it was the MAF, finally I can enjoy my car. Everything is working great, thanks for all the help.
Old 03-11-2010, 01:34 PM
GTstreet996's Avatar
GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !
Best feeling in the world when you sort it out....time to enjoy it now!!
Old 03-11-2010, 02:49 PM
Good to hear.....
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
agentsmurf
Cayenne 955/957
10-17-2015 02:10 AM
whtrabt
10-05-2015 05:23 PM
xbox_fan
10-03-2015 06:21 AM
Boltons991qtr
09-20-2015 06:57 PM
vogz
09-19-2015 01:02 PM
Quick Reply: Misfire or surging above 4500 at WOT ????
