996 Tiptronic 60-130 Times
I'm pretty sure I'm not going to do better than I have, with what I have. Not gonna even try. Just sold my house and have a lot of stuff to do, so it might be a while before I get any more numbers up....
Ahh. Well you've already done some impressive numbers so no need to worry bro!
I always had Brians (vrybad) and he sold it to Dave(flash68). Then I had Tony's for a while and then he needed it back. I can get it if I really need it, but as I said, not really necessary for a while.
Can anyone with a 996 Tip post their mods and 60-130 times (preferably with stock or hybrid K16's on pump gas).
I am trying to figure out why my car is so slow. Apparently, my tip is shifting from 3rd to 4th too early, but I want to see where other people's numbers are at.
My only power mods are exhaust, diverter valves, k16 hybrids and softtronic tune.
It is running 60-130 of 10.1.
Any help is appreciated!!
With your turbos you should at least be in the 8s or low 9s at the worst, imo. Have you tried starting in second gear? Todd (VRTX) has gotten his best times starting in second gear. You should also see if your program allows brake boosting. That will significantly lower your times. Additionally, I would ask Softronic to revisit your tune and see if improvements can safely be made in boost or timing advance. Finally, you should check for any loose hoses or boost leaks to make sure you are not losing performance there.
Yep. That's waymagelli's TIP. Stock K16's with Europipe and Softronic flash.
He also ran 11.67 at 119.
Sounds like I need him to post here.
You dont have one already? How did you measure the 10.1s 60-130?
Yes, the Performance Box gives you everything you need for the lowest price.
